Author Topic: Spacing between rear quarters - 70 Cuda  (Read 946 times)
Offline MR291
« on: July 26, 2005 - 05:42:31 AM »
I have cut-out the lower rear quarters on my 70 Cuda. I have tacked in the replacement panels, but before I do the final welding, I want to be sure that they are in the right position.
Can someone tell me what the correct distance would be between the left and rear quarter from the point nearest to the tire. I forgot to measure before I cut the old ones out.
Appreciate it.
Jerry
Offline hotrod98
    • Maniac Musclecars
Re: Spacing between rear quarters - 70 Cuda
« Reply #1 on: July 27, 2005 - 09:49:48 PM »
Two things need to be done to properly align the new rear lower quarter patch panels. You need to install the rear valance and the wheel opening moldings. I'm serious. There is no measurement, especially one involving the tires since there are thousands of variations. The first time that I installed a set years ago, I installed the rear valance panel, but not the wheel opening moldings. You would not believe how critical this is for the w/o moldings to fit. If you don't have the moldings now and decide to put them on later, you might be screwed as far as proper fit goes. Real world experience talking here. The patch panel may be in slightly in the front and look absolutely perfect until w/o molding time.
Just tack the panels in place until you're sure that the fit is right and then weld em up.
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
Offline MR291
« Reply #2 on: July 28, 2005 - 08:19:03 AM »
Great idea.
I'll do just that.
Thanks.
Jerry
