thermostat housings - B/RB and A differences?
Author Topic: thermostat housings - B/RB and A differences?  (Read 1413 times)
Offline miketyler
    • www.miketyler.net
« on: July 26, 2005 - 06:15:49 AM »
I just received a new water neck for my Mopar MP1intake and it appears to be a wider bolt pattern than the intake requires. There are several delaers selling water necks for 64' and up Mopar V8. Are the big block and small block water necks different?
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline hemi71
Re: thermostat housings - B/RB and A differences?
« Reply #1 on: July 26, 2005 - 09:13:43 AM »
I've only seen differences in the general shape or small details...I think all the muscle car year motors interchange as far as bolt pattern go.
Offline miketyler
    • www.miketyler.net
« Reply #2 on: July 26, 2005 - 09:57:41 AM »
hmmmm....interesting. Small blocks will mount on theintake and big blocks mount on top of the pump? That one in your sig looks larger than mine with the bolts spaced apart quite a bit. Is the Hemi an exception?
72' Cuda restomod
70 Mustang Mach 1
Offline hemi71
« Reply #3 on: July 26, 2005 - 12:48:57 PM »
Not diff on a hemi, matter of fact the hemi water pump housing is a standard big block housing, and my hemi had a chrome t'stat housing that i swapped with one from my stock of housings due to a weeping problem.
Offline hemi71
« Reply #4 on: July 26, 2005 - 12:49:55 PM »
heres a small block
Offline miketyler
    • www.miketyler.net
« Reply #5 on: July 26, 2005 - 01:24:58 PM »
so the big block and small block are the same? I called the vendor and he says he sells these all the time and never has any issues  :dontknow:
Any chance my aluminum MP1 intake is the culprit?
« Last Edit: July 26, 2005 - 02:00:11 PM by miketyler »
72' Cuda restomod
70 Mustang Mach 1
Offline miketyler
    • www.miketyler.net
« Reply #6 on: July 26, 2005 - 05:11:48 PM »
The t-stat housing he sent me measures 3 1/4" center-to-center. My MP1 intake measures 2.90" center-to-center. Can someone tell me who's right here? Check out the pic.
72' Cuda restomod
70 Mustang Mach 1
« Reply #7 on: July 27, 2005 - 02:11:50 AM »
newer small blocks use a smaller thermostat & neck
Offline miketyler
    • www.miketyler.net
« Reply #8 on: July 27, 2005 - 05:14:19 AM »
I guess in the case of the small block, we're really talking about the intake right? So if I had the original cast iron intake from the 340 I'd be in business?  Do you know what year they reduced the size of the housing?
72' Cuda restomod
70 Mustang Mach 1
« Reply #9 on: July 27, 2005 - 04:07:25 PM »
80s for sure are smaller
