Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
Turn signal help
« previous
next »
Print
Pages: [
1
Author
Topic: Turn signal help (Read 1436 times)
Belltone85
Jr. Member
1973 Dodge Challenger 360 Crate Motor, Slap Stick
Turn signal help
on:
July 27, 2005 - 09:17:17 PM »
both of the right side turn signals work front and back but on the left side on the hazards work not the turn signals. anyone help[??
Logged
OUTLAW
MASTER OF ALL THINGS MOPAR
Sr. Member
I didn't say you can't RACE--I said you can't WIN
Re: Turn signal help
Reply #1 on:
July 27, 2005 - 09:27:53 PM »
check the flasher unit
Logged
Belltone85
Jr. Member
Reply #2 on:
July 27, 2005 - 10:43:06 PM »
checked it and its fine
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #3 on:
July 28, 2005 - 01:06:56 AM »
probably in the turn signal switch , the signal to front & rear is different so the brake lights operate on the rear only
Logged
Belltone85
Jr. Member
Reply #4 on:
July 28, 2005 - 11:31:46 PM »
ordered a new turn signal switch. now how hard is it to change this? have to take apart the column obviously..
Logged
Chryco Psycho
Administrator
C-C.com Guru
Reply #5 on:
July 28, 2005 - 11:44:45 PM »
ti is not to hard to change , you need to drop the mount under the column to get the the wiring through , & you need to pull off the wheel & the crush can
Logged
Belltone85
Jr. Member
Reply #6 on:
July 28, 2005 - 11:51:26 PM »
ok thanks should be here on saturday and i will post another if i need help
Logged
Belltone85
Jr. Member
Reply #7 on:
August 04, 2005 - 08:37:45 PM »
how do you remove the crush can??
Logged
FY1 RT SE
Full Member
Reply #8 on:
August 04, 2005 - 08:47:46 PM »
Remove the center nut and then use a steering wheel puller to press it off.
Logged
Belltone85
Jr. Member
Reply #9 on:
August 04, 2005 - 08:52:50 PM »
oh crap i don't have a steering wheel puller
Logged
04lbram
Jr. Member
Reply #10 on:
August 05, 2005 - 04:37:38 PM »
Hey, also keep in mind you're going to have to modify the steering wheel puller with some longer bolts so keep that in mind.
Logged
71 Dodge Challenger R/T Clone; 383 Big Block with a few goodies and good ole 14" Slot Rims
Chryco Psycho
Administrator
C-C.com Guru
Reply #11 on:
August 06, 2005 - 12:16:41 AM »
or get a small puller that fits inside like 4Cs puller
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
Interior and Gauges
(Moderator:
Chryco Psycho
Turn signal help
