Author Topic: Brake problem . . have question.  (Read 776 times)
Offline 4Cruizn
  • HEMI FISH
« on: July 29, 2005 - 07:51:30 PM »
What makes the brake pedal come back up after you push it . . . cause mine won't??
Why do I get a feeling it's vacuum . . .   and I won't have enough.   :newsad:
forsee   (4C)
Re: Brake problem . . have question.
« Reply #1 on: July 29, 2005 - 10:35:08 PM »
mostly it is the hydrauic prssure  combined with the springs in the drum brakes
 master or booster could be a problem or maybe the propotioning valve is restricting some pressure  from returning to the master
Offline 4Cruizn
  • HEMI FISH
« Reply #2 on: July 29, 2005 - 10:43:48 PM »
Well I just installed the new booster today and that is what is happening.  Push on the brakes and the pedal won't come back up!   :gripe:  Looks like I'm not going to the car show tomorrow until I get this figured out.   :dontknow:    Maybe I got a bad brake booster??   :pissed:
Offline Grancoupe
« Reply #3 on: July 30, 2005 - 11:27:36 AM »
I remeber testing brake boosters by pushing down on the pedal when the car is not running. Then start the car and the pedal should drop a bit. If this dosn't happen then the booster isn't working. Give your rear brakes a good look. Make sure you have no air in the lines. Otherwise if might be a proportioning valve.
