Author Topic: heater core bypass  (Read 1050 times)
Offline 300
  • 69 chevelle,67chevelle , 70 barracuda
heater core bypass
« on: July 31, 2005 - 07:29:26 AM »
Hello  I know you can bypas the heater core by connecting the two hoses together, but could you just put a shut off valve on each of the two hoses and get the same result. Thanks Terry
Offline Plum6Pak
  • Plum6Pak
Re: heater core bypass
« Reply #1 on: July 31, 2005 - 07:48:22 AM »
Hey 300, It won't hurt anything to install shut off valves but why do you need to install them? Is the heater not shutting off like it should? Is the heater core leaking? Just curious. You only need to install one valve to stop the flow if it isn't for a leak, if it's the core leaking you will need to install a valve in both hoses.
As an added note, if it's just due to heat in the car, there are many cars that have the vacuum operated shut off valve already in the line just before it goes through the firewall activated by your heat control button or lever, maybe it gave up the ghost. There is a thread that covers this somewhere if you do a search here on the forum.
