Undo the castor struts to thew lower control arms ,back off the T bar adjusting nut , undo the nut on the LCA pivot ,remove the circlip behind the T bar & pry the lower control arm back with the T bar , disconnect the sway bar from the lower control arms as well as well , then undo the steering column from the steering box & undo the 4 big bolts holdin gthe K frame in place
