Slap-Stik Shifting Pattern - Is 1970 Gate the Same as 1971-74?
Author Topic: Slap-Stik Shifting Pattern - Is 1970 Gate the Same as 1971-74?  (Read 4812 times)
Offline Carlwalski
« on: August 07, 2005 - 03:05:41 AM »
Simple enough question but I wouldn't mind knowing.  :thumbs:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Re: Slap-Stik Shifting Pattern - Is 1970 Gate the Same as 1971-74?
« Reply #1 on: August 07, 2005 - 12:06:28 PM »
yes , they actually used the same mechanism into 77or 78 in the Magnums etc
Offline Carlwalski
« Reply #2 on: August 07, 2005 - 08:53:20 PM »
So it is a detent? You can only shift into the next gear? Does this one pop back slightly as well? (Like the 70) :???:
So if I am reading your previous post right, the only thing that changed in 1971-74 is the handle itself?  :D
Sorry CP I am considering converting to the 71-74 handle so want to be 100% sure before I do.  :)
« Reply #3 on: August 08, 2005 - 01:10:56 AM »
only the hnadle changed year to year , the 76-78 used a popished stainless ball
Offline Carlwalski
« Reply #4 on: August 08, 2005 - 01:25:08 AM »
Thanks Chryco.  :thumbs: If I changed to the 71-74 slap-stik unit nothing else like the shifting rods need to be changed aye?  :dontknow:
« Reply #5 on: August 08, 2005 - 07:02:01 PM »
correct , the shifter & handle is all that changed , all the linkage remains the same
Offline Carlwalski
« Reply #6 on: August 09, 2005 - 04:11:45 AM »
Awesome!! Thanks Chryco your a king!  :beer:
« Reply #7 on: August 09, 2005 - 10:36:59 AM »
 :laughup: to quote Metallica "King Nothing "
Offline Carlwalski
« Reply #8 on: August 09, 2005 - 03:27:03 PM »
 :laughup: :grinno:
Offline 74MOPAR
« Reply #9 on: August 10, 2005 - 03:34:37 AM »
 Yup my 78 F-body has the slapstick face plate and mechanisms, but different handle...
74 'Cuda + 73 Charger Rally + $$ + assembly= Noble M400
 03 Ram Hemi 4x4
 78 Aspen Super Coupe
Offline Carlwalski
« Reply #10 on: August 10, 2005 - 03:01:20 PM »
So just for reference you can shift from 1st to second and it WON'T go any further? Then 2nd to Drive and no further?
Cheers for your input mate.  ;)
« Reply #11 on: August 11, 2005 - 12:57:13 AM »
it is  a ratchet shifter , so it only allows i gear at a time so yes it will shift to second from fist then you have to release it momentarily & push again & it will go to third & locks out of neutral until the button is pushed allowing it into N , once in N it can be shfited back & forth between N & D , you need to push the button to get to first which activates the ratchet again
Offline Carlwalski
« Reply #12 on: August 11, 2005 - 01:00:31 AM »
Great, NOW, do you have one for sale!?  :laughing: :dontknow: :D :laughing:
« Reply #13 on: August 11, 2005 - 01:01:19 AM »
Yes I do
Offline Carlwalski
« Reply #14 on: August 11, 2005 - 01:13:59 AM »
Yes I do
 :D Condition? Price?  :D Photos? Paypal?  :D  :laughing:
