it is a ratchet shifter , so it only allows i gear at a time so yes it will shift to second from fist then you have to release it momentarily & push again & it will go to third & locks out of neutral until the button is pushed allowing it into N , once in N it can be shfited back & forth between N & D , you need to push the button to get to first which activates the ratchet again
