Author Topic: 4 Speed frame Pivot Bracket  (Read 1441 times)
Offline 2000gt
« on: August 10, 2005 - 03:01:45 PM »
Hey guys, am currently putting a 4 speed setup in my 70 cuda, at the stage where I am welding in frame cons, torque boxes, new 4 spd tunnel, etc.  Before the car goes to the sandblaster I want to mount the frame pivot bracket for the clutch.  I just ordered a new one from Brewers but don't know how to make sure it is in the right spot???  The car has a small block with bellhousing and trans in it right now that I am using to mock up.  How do I make sure the frame pivot bracket is in the right spot, anyone have any measurements for me???  I don't have a Z bar yet as I am not sure which bellhousing I will be using down the road.  Anything else I should be welding in now for the 4 speed conversion?  Thanks, Tyler
Offline 2000gt
Re: 4 Speed frame Pivot Bracket
« Reply #1 on: August 11, 2005 - 12:21:35 AM »
Anyone???
« Reply #2 on: August 11, 2005 - 01:00:14 AM »
the inner fender has the rubber cover over the area where the bracket is , someone should be able to take a pic for you
Offline 2000gt
« Reply #3 on: August 11, 2005 - 10:43:19 AM »
If someone could take a pic or some measurements I would really appreciate it.
Offline DJVCuda
« Reply #4 on: August 11, 2005 - 11:58:10 AM »
i have an OK pic at home - and will get measurements... not tonight tho, maybe tomorrow.. sorry about the delay..
Offline 2000gt
« Reply #5 on: August 11, 2005 - 12:57:34 PM »
Thank. I appreciate it.  I'm assuming it is pretty critical to get it in exactly the right spot?
Offline DJVCuda
« Reply #6 on: August 11, 2005 - 01:12:52 PM »
this is the only pic I have on my work PC  - right behind the green tape is the bracket.
it locates the Z bar so i would say it would have to be accurate, not presise.
Offline 4Cruizn
  • HEMI FISH
« Reply #7 on: August 11, 2005 - 03:31:09 PM »
DJV . . . You forgot the pic!!  lol
Offline DJVCuda
« Reply #8 on: August 11, 2005 - 08:39:23 PM »
OOPS!
