Author Topic: Help!! Orange peel galore  (Read 1026 times)
Offline Fishy68
« on: August 10, 2005 - 10:34:58 PM »
We finally finished up the underhood of my 68 and had a buddy paint it. The body work came out ok but the paint orange peeled pretty bad. He said it was probably because it was pretty hot and somewhat humid (about 88 degrees and 40% humidity).
Anyway I sure wish it didn't have that nasty orange peel look. Does anybody know anyway to easily get it smoothed out?
Thanks, Tracy
68 Cuda. 360/727 4:10 SG.
02 Dakota Sport 4.7/auto
Offline Carlwalski
Re: Help!! Orange peel galore
« Reply #1 on: August 10, 2005 - 10:36:46 PM »
Buff like made it should remove a lot of it.  :thumbs: I didn't notice but even modern cars (05 etc) have peel.
Just some how PEEL.  :laughing:
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline OUTLAW
  • MASTER OF ALL THINGS MOPAR
  • I didn't say you can't RACE--I said you can't WIN
    • MOPAR-MADNESS  WEB/FORUM
« Reply #2 on: August 11, 2005 - 12:00:06 AM »
lot depends on the paint, some brands will pull a lot of the peel out as it outgasses others when cured in the sun and some not at all. only cure I know of is to wet sand the hell out of it as soon as it is cured, not before or you 3ill have a worse mess than you have now
most times orange peel is caused by too hi air pressure, to wet paint mixture, or shooting the car from to far away from the surface ,
« Last Edit: August 11, 2005 - 12:02:04 AM by OUTLAW »
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #3 on: August 11, 2005 - 06:21:00 PM »
Wet sand and buff or sand smooth and repaint,either way it`s a tough area to work in.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline Fishy68
« Reply #4 on: August 11, 2005 - 11:00:09 PM »
Thanks guys. I have alot of other stuff to keep me busy for the next 3-4 wks. so I guess I'll let it cure good and try buffing. Hopefully that will at least make it look better. I've buffed alot of cars but never tried to take out orange peel. If this weren't such a difficult place to work I'd sand it down and repaint.
I think I'd rather do the whole exterior than under the hood again. So many curves, cracks, and crevices. UGH!!!
« Reply #5 on: August 11, 2005 - 11:24:40 PM »
You could apply another coat of clear & see if it will level out properly , probbaly a lot easier then trying to buff it all out
