How easily should the front disk brake wheels turn.?
Author Topic: How easily should the front disk brake wheels turn.?  (Read 1019 times)
Offline bs549
« on: August 13, 2005 - 04:02:16 PM »
I've got a 74 Cuda with power front disk brakes...when I have the front end jacked up, the front wheels turn free, but seem to have some resistance.  I pulled the front wheel and it almost looks like the brake pad is touching the rotor.
Is this normal?
How free should the front wheel turn?
Thanks!
Offline GoodysGotaCuda
Re: How easily should the front disk brake wheels turn.?
« Reply #1 on: August 13, 2005 - 04:26:51 PM »
There should be some resistance when you turn it. A decent amount of pressure is needed to turn it, like the amount needed to open a somewhat stubborn gatorade  :laughing:. You should not need two hands or have to use a lot of force...kinda hard to describe
hope it helps some..
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline viper11
  • dare to be different
« Reply #2 on: August 13, 2005 - 04:49:03 PM »
disk brake pads ride just touching the rotor as there is no return spring like on the rear drums
a slight scraping noise while the pad drags is normal but when spun should rotate about 1-2 turns before dragging to a stop
« Reply #3 on: August 13, 2005 - 05:19:35 PM »
   :iagree: :iagree: :iagree:
 It seems kind of stupid that the pads would be in contact at all times with the rotor, but that's the way it is. I don't believe it does much for gas mileage either.  :laughing:
Offline RusTy/SE
  • Just havin' fun
« Reply #4 on: August 13, 2005 - 09:52:41 PM »
And even less when driving with both feet as i do. I know it's a bad habit but i've been driving that way as long as i can remember :dontknow:
« Last Edit: August 13, 2005 - 10:55:38 PM by RusTy/SE »
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
« Reply #5 on: August 13, 2005 - 10:42:30 PM »
the pads stay in constant contact to keep the rotors clean , there should be light drag as mentioned above
