Need your help....rebuild the 383 or drop in a 440
Author Topic: Need your help....rebuild the 383 or drop in a 440  (Read 1448 times)
Offline bs549
« on: September 24, 2005 - 07:48:08 AM »
Had the 383 pulled from my'74 Cuda and taken to my machine shop for a rebuild....baaaad news when they got inside, as they'd need to resleve one cylinder due to a ring breaking and scoring the sidewall.
Now for the dilemma....they can either rebuild the 383, or for $300 more, they'll take a core 440 block that they have and build it up for me.
Which way should I go???  Not being a numbers matching car, the 440 seems to be the way to go, as there's not replacement for displacement, and I assume the resale value of the car (not that I'm ever ever gonna sell this car) would be higher with the 440.  What's y'all thoughts?   I need to decide by Monday.
Thanks
Offline Plum6Pak
  • Plum6Pak
Re: Need your help....rebuild the 383 or drop in a 440
« Reply #1 on: September 24, 2005 - 08:34:26 AM »
No contest, for the 300.00 you can't go wrong! For the extra money you'd spend on the 383 to re sleeve it, I'd take the 440 in a heartbeat! What year is the 440?
Offline 71GTX
  • It's a fine line between a hobby & mental illness!
« Reply #2 on: September 24, 2005 - 09:01:23 AM »
My opinion, get the 383 resleeved and continue to run it.....
69 RoadRunner (clone)
70 Cuda 383 4 speed (project) one of the first few off the line at Hamtramck with a 1017XX VIN
70 Cuda convertible 340 4 speed (project)
70 Barracuda (project)
71 GTX 440 4 speed (project)
72 Cuda 340 3 speed (project)
3 Harleys
95 Dodge Ram 2500 Diesel 4x4
Expensive Pee is the end result of Expensive Beer!
Offline Killer_Mopar
« Reply #3 on: September 24, 2005 - 10:00:53 AM »
The problem isn't the 300 dollar difference in rebuild, its the associated hardware for the swap. For instance, you will need a new intake, bigger carb, alt-bracket, and if your car is a manual....you might even need a bigger clutch/bellhousing. I say build the 440 even with the additional cost of those items.....
Offline JS27N0B
  • Member since Jan 28th 2003.
« Reply #4 on: September 24, 2005 - 11:05:23 AM »
The only different item you should need will be the intake. everything else swaps over, brackets and pulleys etc.  Go for the 440!!
2013 Tige' RZR 343hp
Offline gomangoRT/SE
« Reply #5 on: September 24, 2005 - 11:11:53 AM »
The decision is a no brainer...........build the 440.    I have a 70 RT/SE with a blown 383 also.......  everyone digs the 440s and the resale value and hype factor is much greater with the 440s.     I bought a 69HP 440 motor and am building it with .055 over Ross pistons complete Compcams set up, along with quality machine work and a good intake and carb.      Best of luck
Offline Plum6Pak
  • Plum6Pak
« Reply #6 on: September 24, 2005 - 12:22:31 PM »
I agree 100%, there aren't too many things you will need for the swap, the heads will even work, one other thing you will need, the distributor is different. Everything else will interchange. You'll be rockin in no time!!
Offline HemiOrange70
« Reply #7 on: September 24, 2005 - 12:41:14 PM »
Go big-440 all the way
Offline loco340cuda
« Reply #8 on: September 24, 2005 - 02:03:40 PM »
If it was me, I would go for the 440.
1970 Cuda 340 4-speed - now stroked to 416ci (SOLD)
2017 Mustang Shelby GT350
Offline bs549
« Reply #9 on: September 24, 2005 - 02:47:02 PM »
The extra $300 includs a new electronic distributor, new intake and new flexplate, so that's another reason why I"m leaning towards the 440.
Offline R/T
  • Johnson City TN
« Reply #10 on: September 24, 2005 - 03:12:30 PM »
Not being a numbers matching car, the 440 seems to be the way to go, as there's not replacement for displacement, and I assume the resale value of the car (not that I'm ever ever gonna sell this car) would be higher with the 440.  Thanks
Nuff said!!!
1973 Challenger (OO/=====\OO)  440
Hemis and Harleys
2008 Dodge Ram Big Horn Edition  5.7 Hemi
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
« Reply #11 on: September 24, 2005 - 03:47:44 PM »
Go with the 440!!!!
Offline JS27N0B
« Reply #12 on: September 24, 2005 - 08:58:42 PM »
You better tell them to go ahead before they have chance to re-think this!!!!!!!!
Offline bs549
« Reply #13 on: September 25, 2005 - 08:02:27 PM »
Thanks for all of your posts....have decided to go with the 440!  Will give you the buildup info after working with the builder tomorrow.
Thanks!
Offline 74 Cuda
« Reply #14 on: October 11, 2005 - 06:08:59 PM »
GET R DONE with the 440.
