Author Topic: 1973 Challenger Rallye Project w/parts  (Read 5160 times)
Offline RusTy/SE
  • Just havin' fun
« on: September 24, 2005 - 04:40:55 PM »
  This is to let ya's know i've decided to sell my 73 Challenger. The car plus a number of parts i've accumulated over the past 2 1/2 years go as a package deal. I'm asking $6500 for all and posting here before advertising locally in central Alabama (i live in Montgomery). Here are some pictures as well as a list of what goes with her. I'd like to finish and someday drive her but that's not likely so here goes.
  I do have the fins for both fenders. They and the gas cap are from my first Challenger, a 73 Rallye in the same color combo this one came with originally. That's the reason i first got it. I spoke briefly with a previous owner who told me he built the engine currently in it "a 73 318 block with headers, Edelbrock Performer RPM intake, X-heads and Purple Shaft cam". There was a Holley 600 on it as well. Definitely not a numbers matching car. I've had the 727 trans rebuilt, installed correct pulleys for it's current non-air status, a new fuel system from sending unit to carb (now an Edelbrock Performer), new Y1 engine wiring harness, coil, voltage regulator, control module, and new tires. Sheetmetal-wise it needs the pass. side inner fender replaced (replacement goes with the car). As well as those pieces, i have a very nice header panel that goes also. The trunk does have pinholes and a rusted area that prevents one of the four screws that hold the filler-neck-to-trunk floor seal from attaching. The roof at the front windshield looks like someone used pliers and silicone to squeeze the trim together to prevent leaks; i have replacement windshield trim for the damaged pieces. On top it appears as if some softballs were dropped on it. It's not serious but i want to mention the bad points up front to you all. Here's what is on the fender tag...
N85 R11 V6X 26 EN2
H51 J54 M08 M21 N41 N42
V1Y U A57 B41 C16 C56
JY3 A6XW 000 426 322074
E55 D34 JH23H3B458194
  These are the parts that go with this 73 Challenger:
Used passenger side inner fender
NOS side marker lenses
Used 73 Challenger grille support
New AC drain tube
Used 73 Challenger drip rails
Used lower radiator frame
New 340 Four Barrel emblems
Used front windshield trim
Used 73 Chalenger header panel w/headlight rings
Used trunk and quarter panel mldgs
New Legendary Interiors Seat Covers, Headliner, and
Vinyl Top (these are white as i was planning to put
the car back to original colors)
Used 73 Challenger front bumper brackets
Rechromed rear bumper w/support (the inner brace)
Used set of headliner bows (4)
Used 73 Challenger grille mldg and valence mldg
New Y1 Forward Lamp Wiring Harness
Used set of exhaust manifolds (68-70 style) and can
of Exhaust Manifold Coating from Eastwood
New exhaust manifold attaching hardware kit
Used complete set of interior panels (i got this car
with poor quality repro interior panels and through
ebay purchased a complete set of originals that i
had planned on dying, since they are green, with SEMS
plastic paint)
Used set of 73 340 valve covers (cleaned and in
primer)
Used set of "D O D G E" tail panel letters
Used excellent condition trunk lid drilled for the
T/A style poiler
Used T/A style spoiler
Excellent used 71 dashpad with no cracks
New Y1 727A trans cooler lines
Used 727 trans dustcover
Used driver side remote control mirror
  These parts are already on this 73 Challenger:
New front and rear tires
New fan or water pump pulley, crank pulley, and
alternator brackets
New gas tank, fuel sending unit, fuel/vapor lines,
fuel pump, fuel filter, Edelbrock Performer carb
Used 73 340 air breather
Rebuilt 727A trans
New sending unit seal and retainer ring
New fuel filler neck trunk seal, and filler neck to
tank seal
New fuel tank pad (goes between tank and trunk
floor)
Used driver side muffler heat shield (missing when
i got  the Challenger)
New battery, coil, voltage regulator, control
module, and Y1 main engine wiring harness
My plans were for this to be a nice driver quality 73 Challenger although i wanted new items when possible for the important areas such as fuel and electric; the only deviation from stock was to be the T/A style spoiler. This is an AC car originally although all the AC underhood iems are missing. It was like that when i got it. It also appears as though someone tried using the radiator support as a tow point - this is why i've basically purchased a complete group of parts including the grille support, header panel, and font bumper brackets in good straight shape to replace these pieces. I do have the console that was in the car when i bought it. The console door is a green one that had been painted black on the outside.
  I have no doubts about the tranny as it was freshly rebuilt in June '03 and i've put just over a hundred miles on the Challenger since. The engine appears to feel strong once it gets to about 2500 rpm. The previous owner i had spoken with said he built the engine sometime  during 2000 - i only have his words from that one conversation with him (I bought this Challenger in April '03). It seems that the "Purple Shaft" cam has a power band that starts in the low 2000 rpm range and the Edelbrock Performer RPM manifold begins around 1500 rpm. If true then a torque converter with a stall speed to match the cam is needed and was to have been my next step on this car, followed by brakes. I've not driven at sustained highway speeds yet since the brakes haven't been addressed but the few times i've reached the power band, it did feel strong. I've checked the numbers and the block is definitely a 73 318. I drive the car only on weekends and only for short distances (5 -10 miles round trip at a time) due to my uncertainty about the brakes. Feel free to email me at roscoe733@yahoo.com or to phone and leave a message at 334-409-2699.
Russ
« Last Edit: September 25, 2005 - 12:53:31 PM by RusTy/SE »
Russ
2001 Durango     1B4HS
1970 Challenger  JS29U
Offline Hopalong
  • HEAD OFF! Apply directly to the neck line!
Re: 1973 Challenger Rallye Project w/parts
« Reply #1 on: September 24, 2005 - 09:02:05 PM »
I didn't notice, how much are you asking?
Thanks
{oo/===\oo}
Offline RusTy/SE
  • Just havin' fun
« Reply #2 on: September 24, 2005 - 11:15:34 PM »
  Hopalong, i'm asking $6500
Russ
Russ
2001 Durango     1B4HS
Offline RusTy/SE
  • Just havin' fun
« Reply #3 on: September 28, 2005 - 05:59:23 PM »
Car is sold
Russ
2001 Durango     1B4HS
Offline 360 'CUDA
« Reply #4 on: September 28, 2005 - 06:02:29 PM »
Did you get your money?
Offline RusTy/SE
  • Just havin' fun
« Reply #5 on: September 28, 2005 - 11:55:27 PM »
 Got 6k locally...funny thing is the fellow lives two blocks away...he's a good guy and even knew several of the people who owned it before me...sometimes it's a small world :)
Russ
2001 Durango     1B4HS
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
« Reply #6 on: October 11, 2005 - 07:55:06 AM »
Good sale Russ!!  Now on to that RT/SE!!!
Offline 74cuda4spd
« Reply #7 on: October 25, 2005 - 01:35:37 PM »
what engine are you puttin in the rt/se?
'74 'cuda 360 4spd
'cuda..the meanest four letter word
