Author Topic: What's your diagnosis  (Read 3353 times)
Offline 4Cruizn
  • HEMI FISH
Re: What's your diagnosis
« Reply #15 on: September 28, 2005 - 09:30:23 AM »
OK now the car won't start even with a fresh battery.  Sounds too me like we have multiple problems brewing here!
Offline eddie7
« Reply #16 on: September 28, 2005 - 10:41:46 AM »
Is there one thing that could be causing all these problems? I never had problems starting it before. Could a bad voltage regulator cause it to die at idle and also cause it to not start?
I know a bad ignition coil could cause these symptoms, except that when I try to start it, it doesn't turn over. If it was a bad ignition coil it would turn but not fire, so that's not it.
A bad starter would explain the not starting, but wouldn't cause it to die at idle.
I want to cling to the hope that there is only 1 problem. I know there *may* be more than 1 problem, but the fact that all this is happening at once leads me to believe it's just one thing.
« Reply #17 on: September 28, 2005 - 02:45:59 PM »
There is only one thing that I can see that would cause all of this. A bad connection somewhere in the system. Are your battery cables good? Are the battery terminals clean? Does the black battery cable have a good solid connection to the block? Does the red cable have a good connection to to the starter, and starter relay?
Swedefish
« Reply #18 on: September 29, 2005 - 01:48:19 AM »
Agree with Mike
You could try with a jumper cable from battery negative to a place on the engine were you are sure it`s ground (no color and such).
Offline eddie7
« Reply #19 on: September 29, 2005 - 08:12:11 AM »
Thanks for the suggestion. I will take a look at the connections.
