Author Topic: New rims and tires on the Challenger  (Read 3268 times)
Offline EVIL72
« on: September 26, 2005 - 11:16:08 PM »
 Here's a before pic of my 72 Challenger with the polished slot mags on 215/60/14's in the front and 245/60/14's in the back just to compare.
 Then with Centerline Autodrags and BFG T/A Radial tires.
 The fronts are 15x7's with 3-5/16" bs on 225/60/15's
 The rears are 15x8.5's with 4-7/8" bs on 295/50/15's
 ******NOTE: This is on a stock E body width rearend, I HAD to use a 7/16" Mr.Gasket wheel spacers to give the tires at least 1/2" clearance from tire bulge to leafspring, because all it had was 1/16" to 3/16" clearance without them. I also installed 3" long ARP wheel studs and open end lug nuts in the back, so I'd have plenty of threads for the spacers*****
« Last Edit: September 27, 2005 - 12:04:54 AM by EVIL72 »
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
ukneil
Re: New rims and tires on the Challenger
« Reply #1 on: September 27, 2005 - 02:55:12 AM »
what an improvement, amazing look. Well done 8)
what`s the rear spring/shock set up? Standard springs or SStock/retempered? I was talking to a guy at the weekend with a 71 Challenger who had 275/60/15 on the back and he had to have the springs retempered to lift the back end by an inch.
mopar_guy333
« Reply #2 on: September 27, 2005 - 08:02:10 AM »
wow looks great great!she looks...Evil. lol
Offline ROMI
  • 71 Challenger R/T 340 4 speed, Lapeer Michigan
« Reply #3 on: September 27, 2005 - 08:38:35 AM »
I'm impressed Evil, I don't like the look of the ones on my new Challenger and I'm trying to figure out what to go to.  The pics really help.
Very nice.
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
« Reply #4 on: September 27, 2005 - 09:14:44 AM »
Nice change Evil!
Offline Tropicalcats
  • Don't Ever, Ever Give Up
« Reply #5 on: September 27, 2005 - 09:19:10 AM »
Make that looks great.
What a difference wheels can make on the car.
SOLD
Swedefish
« Reply #6 on: September 27, 2005 - 12:23:36 PM »
Looks great Evil.Gives it a nice touch of a racer
Offline Mr. 6pak2go
  • Restore it dont crush it!
« Reply #7 on: September 27, 2005 - 07:34:15 PM »
good job!!
My family, My cars, My guns three things il fight for!!
Offline Carlwalski
« Reply #8 on: September 27, 2005 - 08:11:19 PM »
Sits well!
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline EVIL72
« Reply #9 on: September 27, 2005 - 11:33:31 PM »
 Thanks everyone, and thank's for ALL the info everyone has posted about tire and wheel combo's. It really helped me ALOT in finding the look and stance I wanted.
 I was surprised how much this changed the look of the car, it does make it look even more EVIL!! Muahahahaha ;^)
The shocks are just some stock looking ones, but soon it will get some KYB gas shocks.
 As for the leafsprings, they came with the car when I bought it, the previous owner said he had them done. The numbers on them are 3643594, so maybe someone here will know. The leafsprings have not been moved in either.
 The 275/60/15's have an O.D. of 28.0 while the 295/50/15's have an O.D. of 26.7 so that may help ya with clearance.
ROB
mopar_guy333
« Reply #10 on: September 28, 2005 - 06:47:47 AM »
yup,i agree she sits very nice indeed!
Offline Mr. 6pak2go
« Reply #11 on: September 28, 2005 - 07:19:40 PM »
i agree it does sit nice!!
Offline 4Cruizn
  • HEMI FISH
« Reply #12 on: September 28, 2005 - 08:08:25 PM »
Thats a sweet lookin' car Evil . . . nice job!!
Offline 73 challenger 440
« Reply #13 on: January 04, 2006 - 11:51:08 PM »
would you still need the spacers if you used a 5 inch back spacing?? would it matter if the wheel is 8 inches or 8.5
Offline EVIL72
« Reply #14 on: January 05, 2006 - 05:58:22 AM »
A 5 inch backspacing would make it closer to the leafsprings by 1/8th", with an 8" rim you'd loose the 1/2" on the outside facing the fender if the backspacing stayed the same. It may give ya a little bit on the inside just because it's pulling the tire in farther but I don't think it would be enough to not have to use the spacers. The offset on the pic Chryco posted on your original post works good, I just couldn't get the right offset with the Centerlines.
ROB
