Author Topic: New rims and tires on the Challenger  (Read 3269 times)
Offline 360 'CUDA
Re: New rims and tires on the Challenger
« Reply #15 on: January 05, 2006 - 11:29:07 AM »
Dittos everyone,, Love the Autodrags
(as if you didn't know)
One question though. How much does the wheelstud stick out into the lugnut head?  It is supposed to be 1/2 inch at least.
The reason I ask is Centerlines are pretty thick anyway and with spacers on the back.....
Offline EVIL72
« Reply #16 on: January 05, 2006 - 04:25:41 PM »
That's why I installed some 3" long ARP wheel studs, even with the 7/16th spacers, the thickness of the Centerlines and some open end Centerline lug nuts, I still have 1/2" of the wheel stud sticking all the way out the lug nut. I'm not a big fan of spacers, but I feel better with all those threads there. They haven't been any problem though.
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
Offline 360 'CUDA
« Reply #17 on: January 05, 2006 - 10:14:36 PM »
That's perfect   Thanks!!
Offline EVIL72
« Reply #18 on: January 05, 2006 - 11:00:21 PM »
N/P, Hey 360Cuda or anyone else for that matter, have you had a problem with any of your Centerlines leaking? If so what type of sealer did you use to fix it?  I got one with a pretty good leak and one with a very slow leak. The valve stems and tires are fine, so I know it's the cheap silcone they used to seal the two halves of the rim.
ROB
