fuel tank and breather
Author Topic: fuel tank and breather  (Read 1480 times)
Offline brett
« on: September 27, 2005 - 11:43:34 AM »
i am putting in new  gas tank , in a  73 challenger ,has 4 vent tubes in front of tank , i dont have a line to front for vent  or vapor canister , is there a way  have some type of vent  on the tank or vented cap  that i wouldnt have to run a line to front and add a vapor canister? can i run this with out a vapor canister ?   any ideas on setting this up would be helpful  ,  thanks brett
Offline 4Cruizn
  • HEMI FISH
Re: fuel tank and breather
« Reply #1 on: September 27, 2005 - 11:47:45 AM »
Sure you can run the car without the canister.  I guess I would just plug the 4 outlets on the tank and go from there.  I have a 73 cuda and I don't run the lines to the canister.  The canister is still there but not hooked up!  A vented cap will do the trick!!
Offline brett
« Reply #2 on: September 27, 2005 - 02:20:04 PM »
hi   there    thanks for info  ,thats what ill do ,just cap off the  tubes. i am going to get the 3/8 inch  fuel line for the 440 cause the car  came with a 318.   thanks again
Offline 4Cruizn
  • HEMI FISH
« Reply #3 on: September 27, 2005 - 03:55:19 PM »
Thats a good idea as you would starve that 440 without it!  I had to do the same thing!
« Reply #4 on: September 27, 2005 - 05:27:14 PM »
Brett,
   4C, master-moderator has come thru for you.  :thumbs: You don't really need that charcoal cannister unless you are going for the all correct look in your engine bay. As he mentioned, you might need a vented fuel cap if the one you have is air-tight. I'm still running a 5/16 fuel line with my 440, but I have a high-volume fuel pump to help me out. Believe it or not, 440's drink gas.  :laughing: :laughing: :laughing:
« Reply #5 on: September 27, 2005 - 10:53:48 PM »
the 4 extra lines generally went to a vapor separator in the rear of the car not the canister , at least in 70 -71
Offline skid440
« Reply #6 on: September 30, 2005 - 09:14:15 PM »
Does the standard gas cap (not flip top) vent?  I ask this because on my 70 the vent line that runs from the tank and into the subframe channel seems plugged.  If the cap is vented then I don't need to do anything Right?
« Reply #7 on: October 02, 2005 - 02:56:08 AM »
correct , I`m not sure if your cap will be vented , I think only 70 & some 71s were
