Got motor in...wadda ya think?
Author Topic: Got motor in...wadda ya think?  (Read 2560 times)
Offline RUSTY Cuda
  • One big step foward!
Re: Got motor in...wadda ya think?
« Reply #15 on: September 28, 2005 - 07:30:12 PM »
I should have one of the used ones laying around, if a pic would help let me know & I'll dig it out & shoot it!  Rich.
Offline dwbiggs
« Reply #16 on: September 29, 2005 - 08:24:44 AM »
Rich,
Are you saying that the second time around you got the #7-1590 pn and that is the right one?  A pic would definately help!  More importantly would be the type hose ends.
Dan
Offline dwbiggs
« Reply #17 on: September 29, 2005 - 08:40:59 AM »
ntstlgl1970 ,
The alternator is a Powermaster...think I got it from Magnum HP.  It is a one wire setup with its own voltage regulator.  You have to disable your stock VR and run an ignition wire to the alternator.  Weighs 6 lb less than stock alternator.
Dan
Offline RUSTY Cuda
« Reply #18 on: September 29, 2005 - 07:19:14 PM »
No, didn't get a part # when I went back, so that is probably the wrong #(don't know how the book lists them???)
Stole this off ebay says 71 but looks the same. the pick & the link if you wanna check it out! Rich.
http://cgi.ebay.com/ebaymotors/NOS-MOPAR-2891208-Power-Steering-Hose-70-71-Cuda-340_W0QQitemZ8003798189QQcategoryZ33588QQrdZ1QQcmdZViewItem
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
« Reply #19 on: September 29, 2005 - 08:55:01 PM »
Wow, that engine bay is looking sweet!  Best of luck with it!
Offline ntstlgl1970
  • T a c o c a t
« Reply #20 on: September 30, 2005 - 06:38:07 PM »
Dan,
Thanks for the info!
Eric
