Author Topic: Valve lash on 340 t/a engine  (Read 969 times)
Offline ohio cuda
« on: September 28, 2005 - 08:25:43 AM »
Does anyone have the correct settings on intake and exhaust valve lash settings? Also is it done cold or hot on these engines?
Re: Valve lash on 340 t/a engine
« Reply #1 on: September 28, 2005 - 09:53:57 AM »
if it has a hydraulic cam you need to eliminate the lash & then tighten the adjuster 1/2 turn
 if the engine has a solid cam there would be a spec provided by the cam manufacturer on what the lash should be
