Author Topic: steering shaft coupler rebuild  (Read 5499 times)
Offline EVIL72
Re: steering shaft coupler rebuild
« Reply #15 on: October 06, 2005 - 12:33:47 AM »
 How much did this kit cost ya?
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
Offline miketyler
    • www.miketyler.net
« Reply #16 on: October 06, 2005 - 05:19:09 AM »
about $10 from my local Chrysler dealer
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline EVIL72
« Reply #17 on: October 06, 2005 - 07:24:17 AM »
 Hey I can afford that! LOL
ROB
Offline 4Cruizn
  • HEMI FISH
« Reply #18 on: October 06, 2005 - 09:15:13 AM »
Me either??
Offline CloneTommy
« Reply #19 on: October 10, 2005 - 06:52:17 PM »
I was having a problem with this too...How do you get the roll pin back in where the couple meets the gear out of the steering box?? Maybe freeze it and see if it'll do it for me ;)
Offline Street_Challenged73
« Reply #20 on: October 10, 2005 - 09:52:10 PM »
I'd assume you're having problems aligning the gears on the steering box end.  There is an index spline that you'll need to align on to get everything butted back up so the roll pin can be pressed into position.
Offline CloneTommy
« Reply #21 on: October 11, 2005 - 11:47:27 AM »
I actually got the index spline lined up, It's the one spline that's double wide... I just can't manage to squeeze the roll pin enough to press it back in... I was using vise-grips on it hoping it would compress and start in a little. Then I could softly tap/press it back in.
Offline miketyler
    • www.miketyler.net
« Reply #22 on: October 13, 2005 - 05:42:36 AM »
The main T-pin was a tight fit for sure. Had to back up the shaft with a heavy block to drive the old one out and the new one in. Once I got the clip right,(thanx 4C!) my coupler lined up fine with the master spline and slipped right on. The roll pin drove in easy enough. Actually, the one in the kit looked like it was slightly tapered; not sure if it was a defect or what but it made it easier to start in. You might try tapering one end of yours with a sanding disc. I wouldnt think it would be too bad
72' Cuda restomod
70 Mustang Mach 1
Offline FY1 RT SE
« Reply #23 on: October 15, 2005 - 12:34:04 PM »
This may help.
Offline miketyler
    • www.miketyler.net
« Reply #24 on: October 15, 2005 - 08:21:39 PM »
wow - very nice. Where book did you find that in?
72' Cuda restomod
70 Mustang Mach 1
Offline FY1 RT SE
« Reply #25 on: October 17, 2005 - 04:29:44 PM »
