My '71 resto (updated 10-28-13)
Author Topic: My '71 resto (updated 10-28-13)  (Read 25945 times)
Offline A110235
  • '71 Challenger JH23G1B
Re: My '71 resto
« Reply #15 on: October 15, 2005 - 11:20:45 AM »
I didn’t make as much progress as I wanted to, but I got the rear floor patched in.  I also replaced a piece of metal in the inner rocker where the seat frame attaches.  I put on the new leaf springs, shackles and forward spring mounts and got it back on all fours.  I wanted it mobile just in case my family decided to “Foose my ride” while I am gone.
« Last Edit: December 01, 2006 - 04:58:08 PM by A110235 »
Nashville, TN         Member since October 09, 2004
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
Re: My '71 resto (10-15-05)
« Reply #16 on: October 15, 2005 - 12:43:18 PM »
That made me laugh sooooo hard!
Nice job so far with the metal work.  You are my hero!  I would give anything to learn how to what you have done.  Maybe someday.  Keep up the good work!
Offline Carlwalski
« Reply #17 on: October 15, 2005 - 04:38:34 PM »
April - I agree!! LOL But you should be careful you may have gotten "Pimp my Rided"!! Pink, fluffy interior and green 26" mags!! lol
Looks good mate, hat off to you.....that is some serious work.
I always love seeing these photos, great seeing these cars being treated properly and with care.
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
« Reply #18 on: October 15, 2005 - 06:09:18 PM »
Simply put,....motivational photos. Great work!! I wish I could watch you in person as you are doing all this.
Offline RUSTY Cuda
  • One big step foward!
« Reply #19 on: October 15, 2005 - 06:43:54 PM »
WOW! Nice work, isn't it a great feeling when the rusted crap is gone & your weldin in the new metal! Rich.
« Reply #20 on: October 15, 2005 - 07:00:20 PM »
Just found this place on how to get started.
http://store.cyberweld.com/learningcenter.html
Offline Hemi Challenger
  • Nothing run better then a HEMI
« Reply #21 on: October 16, 2005 - 05:54:24 AM »
Nice work  Like everyone has said you got alot of work ahead of you but it going to be nice when you get done, keep up with the Pic, LOVE them, it make me want to go out and get a Mig welder and try that kind of work on thing that I got to weld
Offline Super Blue 72
    • Phil's Super Blue '72
Re: My '71 resto
« Reply #22 on: October 16, 2005 - 08:34:46 AM »
Are you kidding?
You're going to have your car done before I even get to mount my Go-Wing!
Awesome job and great pics!  This task you're taking on is not for the faint hearted and you're doing a great job!
Offline moparnut
    • My Photo's
« Reply #23 on: October 16, 2005 - 09:46:25 AM »
And so it begins...
The first thing that I needed to address was the roof.  It looked pretty bad, but it was light surface rust and  the only soft spots were near the seam on the sail panel.  After a lot of grinding and some of Eastwoods rust neutralizer it looked decent.  I gave it a quick spray-can coat of primer to hold it for now.
Just a thought for you,Primer's are porous and will let moisture pass thru,Unless you use a primer/sealer/etcher all in one(Great stuff,look at my Sig for Pics on my project Gran Coupe)) like Valpar 2k primer sealer.I am sure a local Valspar dealer could put some in a rattle car for you or buy a gallon and spray it yourself.You will be much happier and safer to your metal,my 2 cents worth
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline A110235
Re: My '71 resto (4-4-06)
« Reply #24 on: April 04, 2006 - 06:32:06 PM »
Well, much to my neighbors dismay, I have started working on my car again.  But before I started anything I welded up a little cart for my welder.  It is so much easier to wheel everything around!
I have ordered both rear frame rail replacements and trunk panels from Sherman.  Today I was working on some metal to connect everything up with the frame piece that I fabricated a couple of months ago.  When I tackle the left side I’ll fabricate one solid piece down to the forward spring mount.
I got the tail lights off and put the back end up in the air again.  It’s at just about the right height to sit on the floor and comfortably work on stuff now.
An this will come in handy for all the little things I’ll have to fabricate/replace along the way.  Thanks Santa Claus!
Luckily I’m unemployed right now (yeesh!) so I’ll be able to put in some good solid days of work on it.  Stay tuned!
Kyle
P.S.  Thanks moparnut for the tip on the primer/sealer.  I’ve picked up a couple of cans.
Offline Plum6Pak
  • Plum6Pak
« Reply #25 on: April 04, 2006 - 07:28:28 PM »
Kyle, you are teaching many of us something about metal work, but also where there's a will, there's a way. Plus determination and confidence! Please keep the pictures coming as you go, these are my favorite kind of threads.
Thanks, P6P
 :thumbsup:
Offline hemi71
« Reply #26 on: April 04, 2006 - 07:50:02 PM »
My hats off to you!  Great work you are doing here...this isn't a restoration or restification, it's a resurrection!
 :cheers:    :thumbsup:
« Last Edit: April 05, 2006 - 10:44:11 AM by Rev-It-Up »
Offline 70RTdroptop
  • 1970 Challenger R/T 440-SixPack
« Reply #27 on: April 04, 2006 - 08:07:43 PM »
 :iagree: Just look forward to the day that all your effort will pay off. I'm sure all of us on this board are cheering you on.
1970 Dodge Challenger R/T 440-6 convertible
1966 Ford Mustang convertible  - numbers matching (wife's car )
Offline Street_Challenged73
« Reply #28 on: April 04, 2006 - 10:27:37 PM »
Very nice progress, A110235!!!  That was a lot of rust to repair, but it's really looking great!!!! :grinyes: :cheers:
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« Reply #29 on: April 04, 2006 - 11:08:14 PM »
I gotta admit when I see this kind of project it's humbling.
Suddenly my "big" problems with my Challenger are more like anoyances.
That said, for whatever reason; when you can't drive your car  :pullinghair:
Anyways....Keep up the good work :thumbsup:
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
