Small block 4 speed parts needed (Updated)
Author Topic: Small block 4 speed parts needed (Updated)  (Read 679 times)
Offline Rough 71 RT
« on: October 08, 2005 - 03:12:04 PM »
i am making the switch from Auto to 4 speed and i am looking for several parts, getting tired of the E-bay thing so if anybody out there has any of the following parts listed that they might want to part with it would be greatly appreciated.
Small block Bellhousing
360 flywheel!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
833 4 speed
Upper clutch rod (For Z-bar)
Shifter (Pistol grip)         (Need the stick only, I have the gate)
console bracket for floor hump
clutch pedal to firewall bracket
4 speed driveshaft or the front yoke for the output shaft
I do have an entire automatic setup i will trade for some of the parts, obviously I'll have a tough time with the 4 speed, shifter, and flywheel, but the rest of the stuff is out there and for what ever reason someone should want to convert from a 3 or 4 speed, I have an entire automatic set up I will trade for. including brackets, cross member, trans, shifter and rods and linkage, etc.  Hope somebody out there has these parts or knows where i can get them BESIDES EBAY
Thanks Dave   By the way this is for a 71 Challenger with a 360   thanks
« Last Edit: November 10, 2005 - 11:40:47 AM by Rough 71 RT »
Dave Carlson
Re: Small block 4 speed parts needed
« Reply #1 on: October 10, 2005 - 12:47:36 AM »
Dean @ >tilleman@telusplanet.net < has some of the parts you need
