Home
Member Rides
Forum
Sponsor Sites
Tools
Contact
News:
Home
Help
Search
Chat
Login
Register
Cuda-Challenger.com
Chryco's Tech Shop
Engine & Go Fast Goodies
(Moderator:
Chryco Psycho
Camshaft
« previous
next »
Print
Pages: [
1
Author
Topic: Camshaft (Read 657 times)
Swedefish
Guest
Camshaft
on:
October 10, 2005 - 11:05:56 AM »
What does the specs of this bumpstick tell you guys and gals.I can`t figure it out. Lift are .444/.445 but the duration? and would you consider this as a good or bad one? For what I know the reading usually is at 0.050 cam lift, or?
Thanks in advance
Logged
Chryco Psycho
Administrator
C-C.com Guru
Re: Camshaft
Reply #1 on:
October 10, 2005 - 11:14:15 AM »
it will not make much power , it has very low duration & will make power from 1500-5000 range , the lift is low so it will hinder flow as well , compare it to the Engle K54 grind , it has more lift & same duration
Logged
Swedefish
Guest
Re: Camshaft
Reply #2 on:
October 10, 2005 - 11:19:07 AM »
Have had that suspicion but wasn`t quite sure,thanks CP
Logged
Print
Pages: [
1
« previous
next »
Cuda-Challenger.com
Chryco's Tech Shop
(Moderator:
Chryco Psycho
Camshaft
