Author Topic: Duster spindles on a 'Cuda?  (Read 1161 times)
Offline mrbill426
    • All Around Mopars
« on: October 10, 2005 - 03:25:36 PM »
By recommendation from another 'Cuda owner I have obtained a set of front spindles off a junked '74 Duster, because I am told they will work fine on the'72 and with more affordable rotors and better replacement calipers available.  If this is a good swap, cool, but is there anything else I would need to change out to use these spindles?  Are the ball joints compatible so the tie rods will line up properly?
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Re: Duster spindles on a 'Cuda?
« Reply #1 on: October 10, 2005 - 05:22:25 PM »
I've got the mid 70's A-Body disc brakes on my 70 Chally. My only question is what front brakes do you have on there now? I mean, drum or disc? The neat little thing I found out on mine, was that the drum brake line from my 70, screwed perfectly into the mid 70's A-body calliper. Go figure.
Offline mrbill426
    • All Around Mopars
« Reply #2 on: October 10, 2005 - 05:37:52 PM »
This '72 has disk brakes up front an 10.5" drums in the rear.
MOPAR or NO car!
Offline mrbill426
    • All Around Mopars
« Reply #3 on: October 10, 2005 - 05:39:04 PM »
Err, maybe that is 10" x 2.5" drums?
MOPAR or NO car!
« Reply #4 on: October 10, 2005 - 05:56:20 PM »
So you are just trying to switch from E-Body disc brakes, to A-Body disc brakes, because it is cheaper?
Offline mrbill426
    • All Around Mopars
« Reply #5 on: October 10, 2005 - 07:30:43 PM »
   Not only quite a bit cheaper (rotors), but I am told the later A-body setup is much better from a caliper design and mounting standpoint and the parts are more plentiful for the later models.  Now, perhaps the later A and E body parts are the same, I just happened to snag the parts from an available A-body.
I am wondering if all the remaining ('72 E-body) components are compatible with this swap.
MOPAR or NO car!
Offline Street_Challenged73
« Reply #6 on: October 10, 2005 - 09:46:07 PM »
As far as I know, '73-up E-bodies use the same rotors/calipers/etc. as the A-bodies equipped with standard discs. ('73+)  As for prices, I'd assume you'd be paying around the same price. :???:
