Author Topic: Where do you mount your amp?  (Read 3124 times)
Offline dwbiggs
« on: October 12, 2005 - 11:07:24 AM »
Am going to be installing nice amp in Challenger.  Where is the best place to install?  Would it go under seat?  Or is it pretty much confined to trunk mount?
Dan
Offline torredcuda
  • Epping NH joined 11/23/03
Re: Where do you mount your amp?
« Reply #1 on: October 12, 2005 - 02:31:27 PM »
I didn`t try under the seat but just see if yours fits.I made a bracket that bolts to the cross bracing in the trunk behind the back seat and with the spare tire in place you hardly see it.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
Offline Street_Challenged73
« Reply #2 on: October 12, 2005 - 03:21:08 PM »
Another thought is to mount it up underneath the package tray.  I know someone who did this and it was a pretty cool idea cause you cannot see it through the trunk unless you're really looking for an amp.  I think he routed the wiring along the V-brace and down into the rest of the light wiring harness back up front.
« Reply #3 on: October 12, 2005 - 03:48:33 PM »
I think you are pretty much doomed to mount it in the trunk, or maybe glove box if you are creative enough. There isn't much room to work with under the seats.
Offline Carlwalski
« Reply #4 on: October 12, 2005 - 06:56:18 PM »
We installed our one on the left hand side of the trunk where the old spare jack use to be.
We made a custom mount that also houses the CD Changer. The CD Changer can be tilted with adjusment bolts.
Very neat set up. :-)
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline GoodysGotaCuda
« Reply #5 on: October 12, 2005 - 09:12:55 PM »
I have a small subwoofer in a box in my trunk. mounted the amp right to the back of the box. makes for easy take out for the track, or if i need the space
1976 Dodge Warlock
Wheel & Tire Specs:Link
Offline 4Cruizn
  • HEMI FISH
« Reply #6 on: October 12, 2005 - 09:58:24 PM »
The trunk does seem to be the answer . . .I have an amp mounted in the trunk of both cars.  Not much room anywhere else!!
Offline Carlwalski
« Reply #7 on: October 12, 2005 - 10:54:51 PM »
Another factor is will you be carrying a spare tyre? If so what size?
I had absolutely no choice but where I did to put mine, I have a 245 spare. lol
Offline R/T
  • Johnson City TN
« Reply #8 on: October 14, 2005 - 07:16:43 AM »
Trunk mounted but i am going to have to redesign the tire mount
1973 Challenger (OO/=====\OO)  440
Hemis and Harleys
2008 Dodge Ram Big Horn Edition  5.7 Hemi
Offline Carlwalski
« Reply #9 on: October 19, 2005 - 06:37:26 AM »
Thought I'd post a few photos of where mine is mounted.
Custom made bracket that holds the Amp and 6 CD Stacker.
You can adjust the stacker (tilt) but you need to unscrew the holding screws. It's VERY tight, no wobbling etc, solid as steel.
Mind the wiring as the loom hasn't been finally fitted and wrapped as yet once it's complete there will be no wiring etc showing. :-)
We removed the old hook for the jack as I'll be getting a more modern compact jack kit.
Also, mind the sound deadener, it's 80% complete along with the grubby brown/black working marks in the deep trunk tray.
Cheers,
Carl
« Last Edit: May 03, 2006 - 03:27:01 PM by Rev-It-Up »
Offline 4Cruizn
  • HEMI FISH
« Reply #10 on: October 19, 2005 - 08:43:21 AM »
That loos SWEET!!  Gonna be an AWESOME ride you got there mate!
Offline Pistol Gripper
« Reply #11 on: October 19, 2005 - 09:31:34 AM »
Gotta admit NZ,  that white shark is growing on me.  The CD changer play through the radio ?
P.G.
O ne
B ig
A $$
M istake
A merica
Offline Carlwalski
« Reply #12 on: October 19, 2005 - 05:50:07 PM »
P.G.
Yip, only problem was that we had to install an aerial switch to manually put the aerial up or down.
That's cool it's next to the steering column. I wanted to have that because if I listen to the CD which will be 95% of the time I didn't want to have the aerial up so I can have the aerial up down half way and everywhere in between. The CD stacker works with the same company's (Pioneer) head unit...Thanks for the comments lads....shes getting there been a while but worth the wait. :-)
Cheers,
Carl
« Last Edit: May 03, 2006 - 03:28:17 PM by Rev-It-Up »
Offline xblade
« Reply #13 on: October 21, 2005 - 07:02:50 PM »
What are you guys doing for speakers and whats the set up look like? I know your not using 6x9's?
Offline Carlwalski
« Reply #14 on: October 21, 2005 - 07:24:06 PM »
I'm using 6x9 speakers. I didn't want any subs etc, extra weight (although good for traction) and I didn't want the "Boy Racer" image.
I'm using Pioneer 6x9" TS-A6991S Speakers, with 460watts and a powerful amp running them I'll have loud clear crisp music.
Ideal for my taste in music, Rock n Roll. AC/DC, Rolling Stones, CCR, The Doors, Geroge Thorogood, Chuck Berry etc......
I'm fitting my speakers in the stock location. Everything will apear to be original but not. lol
« Last Edit: May 03, 2006 - 03:29:08 PM by Rev-It-Up »
