Author Topic: Aluminum 340 heads  (Read 4747 times)
Offline EVIL72
Re: Aluminum 340 heads
« Reply #15 on: November 14, 2005 - 06:07:22 AM »
I typically get a 41 hp gain swapping on juckyard 308 truck heads , great bang for the $$
 the eddys I looked at were not as well designed as the 308 heads & had bad core shift
Chryco when you get 41 hp what all are you doing to these heads? Are you adding oversized valves too, if so what size valves? or do you just do some pocket porting and port matching?
ROB
1972 Dodge Challenger 340ci
1970 Pro Street Duster (Under Construction)
Offline Harkonnen
« Reply #16 on: November 14, 2005 - 06:46:57 AM »
I wonder how the 340 HEMI heads perform compared to the x-heads
« Reply #17 on: November 14, 2005 - 11:16:20 AM »
actually that is using the stock 1.88 / 1.60 valves but with porting done both in the pockets & opening up the heads at the gasket , the pushrod wall cannot be opened up extensively due to the larger than nomal hole for the pushrod but the exhaust side can be opened up a lot on the roof & sides of the port , I do not touch the floor of the port
you can install the 2.02 intake valves as well
 I have no experience with the small block Hemi heads so it is hard to say how they would peform
Offline EVIL72
« Reply #18 on: November 14, 2005 - 11:33:29 PM »
 Thanks for the info Chryco, I'll have to hunt down some 308's for my 340 to go along with the Air Gap RPM I just picked up.
ROB
« Reply #19 on: November 16, 2005 - 01:10:30 AM »
Ok , You are welcome
