Author Topic: Rotisserie Q?  (Read 1175 times)
Offline shatar4
  • 71 Challenger
Rotisserie Q?
« on: October 16, 2005 - 03:54:39 PM »
Has anyone taken off their k member while the car is on a rotiiserie? I need to get mine powdercoated and has to be done before it gets painted.
1971 Triple black 340 Challenger
Offline ChallengerVert
Re: Rotisserie Q?
« Reply #1 on: October 17, 2005 - 12:40:12 AM »
Yes, you can take it off as long as your Rotisserie connects to your frame rails.  You should pulll everything off anyway prior to putting the body on the rotisserie.
1970 Dodge Challenger Convertible 493 6 Pack, 4 Speed
1971 Dodge Demon 408 5 Speed
Offline shatar4
  • 71 Challenger
Re: Rotisserie Q?
« Reply #2 on: October 17, 2005 - 10:01:50 AM »
Mine are connected to the frame rails and everything that can come off, is off. What I was worried about is the flex in the body because evrything is off and thats one of the major connecting points.
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
Re: Rotisserie Q?
« Reply #3 on: October 17, 2005 - 10:11:54 AM »
I wouldn't be worried about the flex unless you have some serious inner fender rust or front frame rust.  My car was bolted to my rotisserie using the bumper mounting holes, had my everthing striped off the car, and even transported the car still on the rotisserie.
Re: Rotisserie Q?
« Reply #4 on: October 17, 2005 - 11:58:13 AM »
Be forewarned shatar that if you are going to powder coat the entire car that there is a tar like material between many panels that will melt out when the chassis is in the oven curing phase of powder coating.The oven must reach 400 degrees for powder coating to crystalize. I was going to go do the same to mine, but I backed out of the idea. Good luck.
Offline shatar4
  • 71 Challenger
Re: Rotisserie Q?
« Reply #5 on: October 17, 2005 - 12:17:25 PM »
I'm not going to powdercoat the entire car (even tho it seems like it), just the K member. I was worried about any flex in the body if I took it off while the body is on the rotisserie.
Offline Mt.St.BigBlock
Re: Rotisserie Q?
« Reply #6 on: October 17, 2005 - 01:13:32 PM »
Hi, Like Hemidog said, as long as the front inner fenders and frame rails are not rusted thin,
you should be fine pulling the K off with it hanging on the rotisserie. Very good question though!!
If structure is in question, I'd set the car top up before pulling it off and then run a nice sized
piece of angle iron across the K's mounting holes , say from the front hole on one side to the
rear hole on the other. That might keep things aligned and help it not sag when you flip it
on its side again. Easy, cheap insurance I guess!   Jeff
71 cuda 383 3spd manual gy9
Re: Rotisserie Q?
« Reply #7 on: October 17, 2005 - 01:42:52 PM »
Just  mis understood you on that. I powder coated my K member. Before I did, I ground off any old slag and mig welded small crevices to smooth it out. Additionally, I beefed up welds around the mounts and smoothed them out with small grinders. Prepping your K member before powder coating makes a world of difference. I probably put in 20 hours of work on it. But it was worth it.
