Author Topic: Heater Plumbing....in-line valve  (Read 1272 times)
Offline cuda-cable
  • MOPAR or no car
« on: October 17, 2005 - 06:37:50 PM »
In the process of putting my engine plumbing in and saw a couple cars this summer with a 'bypass valve of sorts?' in their heater hoses about mid way to firewall. I'd seen others with a 'shutoff valve' just in the one line feeding the heater core. 2 questions whats the advantage  and if so does any body have the part I.D.. for the bypass valve since it looks more of a factory correct thing to do.......also in a 340  what   temp of thermostat  should I  use.?........thx.......dk
Re: Heater Plumbing....in-line valve
« Reply #1 on: October 17, 2005 - 10:32:49 PM »
I believe the "bypass" valve was used on AC cars only
Offline gtx6970
    • A+M Hightech Automotive
« Reply #2 on: October 22, 2005 - 04:15:02 PM »
Correct, Water valve is the proper name, It's an AC car only thing.
Bill Allphin
What can we do for your car.
« Reply #3 on: October 23, 2005 - 01:22:55 AM »
I use a 160 unless it runs above 160 all the time then I use a 180 * thermo
