Author Topic: 360 Bearing Clearance Problem  (Read 810 times)
Offline matt63
« on: October 20, 2005 - 08:20:39 PM »
I just installed my 4" Eagle crank and plastigaged the main bearings.  I'm getting 0.004" all across which is too big.  I'll try it again and see what I get.  Otherwise its off to the machine shop for some measuring.  Anybody had this problem?  The bearings are Speedpro 120Ms.
Matt in Edmonton
'68 Valiant
Re: 360 Bearing Clearance Problem
« Reply #1 on: October 20, 2005 - 09:53:46 PM »
not cool , we will be setting up an eagle crank in the next day or 2 will check the clearance on that
Offline matt63
« Reply #2 on: October 21, 2005 - 06:35:44 PM »
It looks like the crank is about 0.0015" under the nominal size.  I can get bearings 0.001" small I am told.  This should give me about 0.003" clearance which is max clearance I would think.  I am using SpeedPro (Federal Mogul) mains as Clevite doesn't list a chamfered bearing for the 360 although I am not 100% sure I need them.
Matt in Edmonton
'68 Valiant
Offline cutting torch
« Reply #3 on: October 21, 2005 - 06:50:11 PM »
How was the thrust? My 4" Mopar crank would not drop into the block with the # 3 bearing in place. It was hitting the rear of the #4 main web. Indexing and journal sizes were dead nuts, at least.
torch
Offline matt63
« Reply #4 on: October 21, 2005 - 08:15:53 PM »
I haven't checked the thrust yet.  The crank does fit.  I was going to check the main clearances and then lube it up to check the total endfloat.  I may have been wrong about the journals being undersized.  I assumed that they were 2.812.  I measured them at 2.810.
Matt in Edmonton
'68 Valiant
