Author Topic: cam break in - how soon after first start?  (Read 4223 times)
Offline wart1de
    • Vivah
Re: cam break in - how soon after first start?
« Reply #15 on: October 23, 2005 - 08:39:48 PM »
Sorry to talk other brands but I recently had some dramas on the initial startup of the new 351C I put into my Falcon which i'm driving around while my 'Cuda is getting it's chassis repaired..   After alot of cranking of the starter and making several batterys flat I realised it just wasn't going to start.. After a compression test which showed I had none I found that the pushrods were too long and were preventing the valves from closing... I fixed that, got it fired and did the usual 20-30min run in at 2500..
I've put around 7000 on it since then but I have noticed a little bit of lifter noise lately ( new comp cams antipump lifters ) ..  Do you think if it's still running ok by 7000 it's ok or could I be stuck with two cars off the road soon :(
1973 Plymouth 'Cuda
1980 Ford Falcon XD ESP
2012 Jeep Wrangler Rubicon
« Reply #16 on: October 23, 2005 - 11:28:09 PM »
I could only guess , possibly you have a problem or maybe not , check it out
dodgetkboy78
« Reply #17 on: October 23, 2005 - 11:32:10 PM »
Quote
new comp cams anti-pump lifters
LOL!.........................LOL!...........................LOLOLOLOLOLOOOOOOLLLLOOOLLL!!!!!!!!
Joint the club!
I have three sets of these lifters in the yard, in engines, one has a flat cam lobe, and two clatter, including my Dually.
I think we are better off with the cheapo lifters.
