Author Topic: 392 Hemi rear oil seal  (Read 2755 times)
Offline 67Vette427
  • My other car is not a Rambler
« on: October 23, 2005 - 12:02:15 PM »
Hi,
I'm rebuilding a 58 392 Hemi. The Fel Pro gasket set supplies the rope seal and a rubber seal that goes foward of the rope seal. However, the rubber seal does not sit flush with the ends of the block or the main cap. That doesn't seem right. Any ideas?   Thanks
1 of 1 Mr Norm's T/A/ 2015 Hellcat, sublime/ 13 Power Wagon
Re: 392 Hemi rear oil seal
« Reply #1 on: October 23, 2005 - 12:10:44 PM »
the rope seal is the rear main seal , the rubber seal does not go in there , the inner groove is the oil slinger groove
Offline 67Vette427
« Reply #2 on: October 23, 2005 - 12:45:55 PM »
Thanks,
Do you know where that rubber seal goes? Its the diameter of the crank main journal and has two little tabs on one half.
Offline 67Vette427
« Reply #3 on: October 23, 2005 - 01:44:41 PM »
Ya know the gasket kit also does 354 and smaller. Its probably one of those that uses the rubber main seal.
« Reply #4 on: October 23, 2005 - 11:19:00 PM »
sounds like the small block rear main , possibly a seal for a polyl
Offline Crazy440
« Reply #5 on: October 23, 2005 - 11:43:58 PM »
Check this site out.  Lot's of Old Hemi info, over there.
http://www.thehemi.com/forums/index.php?sid=467b2b4eb8856be839723e7473548b2c
Offline 67Vette427
« Reply #6 on: October 24, 2005 - 05:46:21 PM »
That is a cool site. I'm going through it now. Thanks!!
