Author Topic: 727 application differences???  (Read 1457 times)
Offline moparnut
    • My Photo's
« on: October 23, 2005 - 05:59:31 PM »
I know the 727 linkage is all the same on B,E bodies but what about the trans mount?Can you put a 727 from a B body in an E body?Will a 727 from a 69 pickup have the same trans mount as an E body?thanks for any help
2012 Subaru Forester
70 D100 Adventurer 383 pickup
06 Honda VTX1800S Spec 3
Offline JS27N0B
  • Member since Jan 28th 2003.
Re: 727 application differences???
« Reply #1 on: October 23, 2005 - 07:34:17 PM »
Car transmissions are the same as they have the same length tailshafts, as long as we are talking 727 to 727, some do not have the provisions for the floor shift bracket though so double check that.
You should measure your truck tailshaft extension housing as it may be the same, there were some truck trannies that had short tailshafts however.
2013 Tige' RZR 343hp
Offline moparnut
    • My Photo's
« Reply #2 on: October 23, 2005 - 07:44:03 PM »
Da all i needed to do was go out with a tape measure,lol.Guess I am taking the easy way out and also just trying to be sure,thanks for the reply
Offline mrbill426
    • All Around Mopars
« Reply #3 on: October 24, 2005 - 10:39:48 AM »
Okay, along those lines I now have a 440 and 727 combination that will come out of a '66 D Body (Imperial), should that be a simple bolt-in into our '72 E body?
We just obtained this Imperial as a parts car for our '64 Imperial, and with that 440 just sitting there doing nothing we are thinking of dropping the 340 rebuild and adding an extra hundred cubes under the 'Cuda's hood.
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
« Reply #4 on: October 24, 2005 - 10:59:20 PM »
the Imp drivetrain will bolt in , the problem MAy be the linkage support bracket tabs on the extension housing if you are using the floor shift
Offline mrbill426
    • All Around Mopars
« Reply #5 on: October 25, 2005 - 09:13:30 AM »
OK, any chance the extension housing off the small block's 727 will fit the 440?
Does that just go for the stock floor shift, would an aftermarket morse cable shifter solve that one?
Thanks!
MOPAR or NO car!
« Reply #6 on: October 25, 2005 - 01:06:23 PM »
the small block tail housing will work , it is identical
 the cable shifter will solve the problem also
Offline mrbill426
    • All Around Mopars
« Reply #7 on: October 25, 2005 - 11:25:34 PM »
Way cool, thanks Chryco!
I'm going to do all I can to salvage this slap stick, I hate the idea off cutting off the original shifter brackets and tossing the original console.
I do have a Winters reverse pattern shifter boxed up in the shop that I bought a year or so ago, but the more I look at that swap the less I like it.
MOPAR or NO car!
