Author Topic: Why would anyone do this??  (Read 3762 times)
Offline Super Blue 72
    • Phil's Super Blue '72
Re: Why would anyone do this??
« Reply #30 on: October 30, 2005 - 09:18:44 AM »
LOL!  Would that make it a Cara-Cuda or a Barra-van?
Offline b5blueaar
  • Mad Max Cuda
« Reply #31 on: October 30, 2005 - 06:24:47 PM »
hey hotrod98,
when you weld in the gill panels, do you weld solid or just short tacks every 2 inches?
if every 2 inches, are you using the jb weld to fill between the welds?
thanks
Offline hotrod98
    • Maniac Musclecars
« Reply #32 on: October 30, 2005 - 09:05:04 PM »
Weld it all of the way around. Just keep tacking every inch or so to keep the heat down. I usually weld a spot and then cool it down with an air blower. Don't use water to cool it down, it contaminates the weld area. After it's welded all of the way around and then ground down, use the J B Weld to fill the little holes that you always get around the welded area. Just lightly grind the back side of the fender down. Since it's never seen, it's better to leave more weld there on the back side for the strength. Be careful when you grind on the fender, since it can distort the metal. Grind a little and cool it down occasionally. If you distort the fender, it will be difficult to correct. Those punched areas are weak. Let the J B Weld sit overnight, grind it smooth and apply a polyester skim coat. Here's a pic of the 73 fender. I've already J B Welded it and have applied a polyester skim coat.  Note on this fender that I've already recessed the side marker lamps. That's another project.
1971 Cuda, Tor-red, Bench seat
1971 Cuda Drag Car
1973 Cuda Clone, EFI/OD Limelight
1970 Superbird (Yes, it's real) Black Ice
1971 Barracuda Sassy Grass Green (sold)
1970 Challenger RT SE 383 Plum Crazy
1969 Road Runner Hardtop
1968 Road Runner Coupe (sold)
www.maniacmusclecars.com
Offline gn300
« Reply #33 on: October 31, 2005 - 10:46:16 AM »
Are we missing the 70 stripe thats confusing 71 gills, 70 stripe,but mabe he wanted some from every year, so where are the 74 bumperetts?Just kidding.
Offline AprilsPink72Cuda
  • Global Moderator
  • 1972 'Cuda 340/Wappingers Falls, NY
    • Klondike's Website (Check it out!)
« Reply #34 on: October 31, 2005 - 05:43:01 PM »
Nice work Hotrod!
Offline hotrod98
    • Maniac Musclecars
« Reply #35 on: October 31, 2005 - 07:31:10 PM »
Believe it or not, my wife insisted on the 70 hockey stick. I told her that we're confusing people enough as it is. When I told her it was the gills or the hockey stick, she wasn't about to give up those gills. So the finished product has gills, color keyed grille, recessed side marker lamps, bumpers painted and tucked in, fuel injection, overdrive transmission, cruise control, A/C and Hopster wheels with Eagle F1 D3 tires.
1971 Cuda Drag Car
Offline Blackcuda
« Reply #36 on: November 02, 2005 - 12:43:17 PM »
At Barrett Jackson in AR. early this year, there was a 70 Cuda convertible that had the 71 gills. According to what the owner of the car said, that late in 1970 when the 71's came out. Some dealers would install the gills on left over 70's because people liked them so much. That car had dealer installed gills.
There maybe a pic on the BJ website.
