hello,
It helps once you pull the screws to heat it up a little with a heat gun or your wife hair dryer. Not a torch! lol
there rather simple to take off, just pull the weather strip back real slowly a little at a time be sure not to tare it, then theres a bunch of screw holing the inner on then the drip rail will have some screws on it also that you will have to pull the just heat it up a little and carefully pull the drip rail off, be sure not to twist it or bend it!
good luck,
Jesse
P.S. stop by sometime cudaregistry.com
