#'s Matching ?
Author Topic: #'s Matching ?  (Read 1887 times)
Offline JRoss22
  • Member Since 05/08/2005
#'s Matching ?
« on: October 29, 2005 - 12:01:20 PM »
I was curious as to how you tell if you have a numbers matching engine because just recently I found out from my dad that my uncle either dropped a new engine into or rebuilt the old one but he wasnt quite sure on that. So I was just wondering on that one because the shop teacher at my school gave me a wondful idea instead of rebuilding the engine I have right now. I can take this class at the local community college two days a week and the class cost $110 and I can learn how to rebuild and machine engines. Well he told me I should find a 360 and pull it out of a truck then build up that engine put it inthe challenger and set aside the 340 until I get ready to either sell the car or take it back to stock. So I was wondering if anyone also knows of a place where I can get a decent 360 engine? And my teacher is also giving me a letter of recomendation to apply at dodge because he knows alot of the people that work there so maybe by then end of this month when I turn 18 I will be working for them.
Offline 360 'CUDA
Re: #'s Matching ?
« Reply #1 on: October 29, 2005 - 12:59:13 PM »
Sounds like a good idea to me
360s are cheap and you can build one to go at least as fast as a 340
Hopefully you will find that the 340 in your car is original but if it's no then sell it and use the money to build the 360
2 cents please   ;)
Re: #'s Matching ?
« Reply #2 on: October 29, 2005 - 04:57:37 PM »
2 cents please   ;)
 I have to agree here. If the 340 isn't original, you can do as much with a 360 that will be easier to find.
Offline 04lbram
Re: #'s Matching ?
« Reply #3 on: October 29, 2005 - 05:02:06 PM »
While these two people have a point I personally am not impressed with a 360. I don't know even if the 340 isn't original I would just build up the 340 engine because to me they seem to run a little better given the same mods as a 360. I know this because my father had a built 73 360 put in his Charger and now he has a lightly modded 340 and what a difference using the same tranny and gears.
71 Dodge Challenger R/T Clone; 383 Big Block with a few goodies and good ole 14" Slot Rims
Offline Tropicalcats
  • Don't Ever, Ever Give Up
Re: #'s Matching ?
« Reply #4 on: October 29, 2005 - 05:39:52 PM »
This should help it checking to find out if your current engine is # matching.http://challenger.mpoli.fi/forum/viewtopic.php?p=4119
SOLD
Offline JRoss22
Re: #'s Matching ?
« Reply #5 on: October 29, 2005 - 05:48:28 PM »
wow reading that i got really confused is there anyway that you could explain that so its less confusing?
Re: #'s Matching ?
« Reply #6 on: October 29, 2005 - 05:52:31 PM »
The engine marking ( Vin Number) is on the passenger side of the engine just above the oil pan. It's a little bit more than mid way and towards the front. You will probably need to wipe of they area to see the Vin. If it matches  your Vin number you have a matching numbers engine.
Hope that helps.
It can be hard to get far enough under the car to see it.
SOLD
Offline JS27N0B
  • Member since Jan 28th 2003.
Re: #'s Matching ?
« Reply #7 on: October 29, 2005 - 06:12:24 PM »
If the mods are the same the 360 will always make more power because of the extra cubic inches.
2013 Tige' RZR 343hp
Offline 360 'CUDA
Re: #'s Matching ?
« Reply #8 on: October 31, 2005 - 06:19:58 PM »
Correct
Offline JRoss22
Re: #'s Matching ?
« Reply #9 on: October 31, 2005 - 07:09:02 PM »
Well i struggled to get underneath the car far enough to see the numbers on the blockbutno luck couldnt see them i guess i will need to get the car liftedfrom both side on jack stands to be able to find it and have a better lite source than the little lflashlight on my cell phone
Re: #'s Matching ?
« Reply #10 on: October 31, 2005 - 07:27:10 PM »
They can be very tough to see. If you can get a trouble light that should help.
SOLD
Offline JS27N0B
Re: #'s Matching ?
« Reply #11 on: October 31, 2005 - 09:34:06 PM »
Look below the left cylinder head on the front of the block, this has all the engine numbers stamped there including the plant,build date,number produced and cubic inches.
Re: #'s Matching ?
« Reply #12 on: November 05, 2005 - 08:45:55 PM »
J
Are you  numbers Matching?
SOLD
Offline JRoss22
Re: #'s Matching ?
« Reply #13 on: November 06, 2005 - 12:52:18 AM »
I havent had the time to look lately because I have been working quite a bit lately and then allmy weekends are taken up with marching band comps this month.
