E-body rear bumper/brackets
Author Topic: E-body rear bumper/brackets  (Read 1502 times)
Offline dwbiggs
« on: October 31, 2005 - 11:25:54 AM »
If I want to move my rear bumpers in closer to body and get rid of those filler pieces, could I use '70-'72 bumper brackets? Would a '74 bumper work with these brackets or would I need '70-'72 bumpers as well?
Thanks,
Dan
Offline 4Cruizn
  • HEMI FISH
Re: E-body rear bumper/brackets
« Reply #1 on: October 31, 2005 - 11:40:45 AM »
You would need the 70-72 bumper brackets (I will look, may have a pair) but the 74 bumper will have different mounting holes.
Offline pettybluecuda
  • www.cudaregistry.com
    • 70-74 barracuda-cuda' registry
« Reply #2 on: October 31, 2005 - 11:44:30 AM »
Hello,
Make sure you get the earler 72 brackets because mid year they went to the style you have now. Well good luck! Stop by sometime www.cudaregistry.com
Later,
Jesse
Offline mrbill426
    • All Around Mopars
« Reply #3 on: October 31, 2005 - 12:06:54 PM »
Speaking or rear bumpers on a '72, how do you get it off?  I admit I have not looked under there yet but it looks AWFUL tight.  Do I have to remove the rear valance first?  It's probably going to come off eventually for body work, but....
I had one HECK of a time taking the front bumper off, the brackets would not clear the grill and I ended up cracking it!  Guess I did not follow the secret sequence.  I have a '72 factory body manual but it does not say much.  Actually it "speaks" in broken english.  :o\
Just got our "new" rear one from the re-chrome shop, looks terrific, better than I have seen from many other suppliers  :o)
MOPAR or NO car!
'72 'Cuda 340, white on white
'72 Sebring; bracket project
'66 Imperial Crown; parts car
Offline 4Cruizn
  • HEMI FISH
« Reply #4 on: October 31, 2005 - 12:11:22 PM »
Take the rear valance off for sure!!  Then there are 4 nuts that hold the brackets to the frame.  SO really you will be removing the bumper and brackets all at the same time!
Offline dwbiggs
« Reply #5 on: October 31, 2005 - 12:15:12 PM »
4cruzin,
I have a Challenger...are Cuda brackets the same?
Dan
Offline 4Cruizn
  • HEMI FISH
« Reply #6 on: October 31, 2005 - 12:18:18 PM »
4cruzin,
Dan
hmmmm     That is a question that I'm not sure of the answer on the rear.  I know the fronts are definitely different but not sure of the rear.     Someone will know!
Offline mrbill426
    • All Around Mopars
« Reply #7 on: October 31, 2005 - 12:26:44 PM »
Cool, thanks!
Hope it goes smoother than the front did.  I got the front bumper separated from the brackets thinking they would slide right out by themselves, but noooooo, I still ended up cracking the otherwise PERFECT grill, grrrrrrrrr!  It later broke into two pieces at the "thin" area below the headight!!  Anyone know of a good "glue" for that fix?
MOPAR or NO car!
Offline 4Cruizn
  • HEMI FISH
« Reply #8 on: October 31, 2005 - 12:31:59 PM »
There was someone on here talking about a plastic apoxy that worked really good but I can't recall who . . .    But I think that is the answer.  You might check with alltrim as they do alot of repairing of grills and would probably have the answer to that question!
« Last Edit: October 31, 2005 - 11:32:57 PM by 4cruzin »
Offline mrbill426
    • All Around Mopars
« Reply #9 on: October 31, 2005 - 12:37:35 PM »
Okay, thanks.
I'm up to my ears in front end work right now, but I want to be ready to deal with it when after the car is painted it's time to put the trim pieces back on.
This is a one paycheck at a time project, figure by next Summer it might be running again.  LOL
MOPAR or NO car!
« Reply #10 on: October 31, 2005 - 01:36:50 PM »
just to let you know the challengers are differnet. Good luck!
« Reply #11 on: October 31, 2005 - 03:34:54 PM »
  I agree. It would be nice if all E-Body parts were created equal, but that would make it too easy for us(banghead smiley).
