Check this out!!!
Author Topic: Check this out!!!  (Read 805 times)
Oldschool
Check this out!!!
« on: November 03, 2005 - 08:52:44 PM »
I don't know if ya'll know about this product or not.  I thought that this product had been outlawed for many years.  I happened upon this while googling fuel requiremnets and compression ratios.  This company sells tetraethyl lead to consumers complete with mixture ratios to raise octane as high as you need it to be.  Some of you folks with high compression engines or engines that tend to run a little hot need to give it a look.  A little pricey, but if it works, it's worth every penny. The website is www.kemcooil.com
When you get on the site, click on the "Octane booster" link and then the "more info" link.  Pretty cool stuff.......Oldschool
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
Re: Check this out!!!
« Reply #1 on: November 04, 2005 - 10:20:11 AM »
Are you going to try it OldSchool?
Oldschool
« Reply #2 on: November 04, 2005 - 10:38:12 AM »
I will probably buy a small quantity and check it out.  I won't do it until the weather gets hot again. Probably next summer when the temps are in the 90's and the cruisin is slow. I'll let ya'll know how it works......Oldschool
