Lens polishing
Author Topic: Lens polishing  (Read 2515 times)
Offline Tropicalcats
  • Don't Ever, Ever Give Up
Lens polishing
« on: November 05, 2005 - 08:53:02 PM »
What is best to use when I restore the lens on my car.
 I have some very light scrathes will this remove them?
 I will need to replace the side markers but the rear look good.
SOLD
Offline Rev-It-Up
  • Global Moderator
  • Member Since 2/20/02
Re: Lens polishing
« Reply #1 on: November 05, 2005 - 09:38:04 PM »
Hey Tropical.  I restored our lenses.  Ours also had some light scratches...some heavy scratches.  I used the Nuvo-Shine kit that Year One sells.  I haven't found anyone else that sells the stuff.  I wish I would have taken before pics to show the difference, but here they are after I finished.
Re: Lens polishing
« Reply #2 on: November 06, 2005 - 11:45:54 AM »
As always thanks Rev.
 I will give it a try. Any special tricks or just follow directions?
SOLD
Offline Rev-It-Up
  • Global Moderator
Re: Lens polishing
« Reply #3 on: November 06, 2005 - 09:58:33 PM »
Just follow the directions.  You'll be sure you've made a bad mistake when you see how dull it gets...but it does get better, I promise.
Offline lemurfart
Re: Lens polishing
« Reply #4 on: November 07, 2005 - 05:27:54 PM »
those look damn good that stuff must work
2008 Ducati 1098 - Flat Black :)
1972 Dodge Challenger 340-4-4speed pistol
Offline Rev-It-Up
  • Global Moderator
Re: Lens polishing
« Reply #5 on: November 07, 2005 - 07:19:26 PM »
Thanks.  If I can do it anyone can!  You basically just wet sand it using several different grits of paper. Then polish.  Everything comes in the kit.
Offline miketyler
    • www.miketyler.net
Re: Lens polishing
« Reply #6 on: November 07, 2005 - 08:38:38 PM »
Nuvo-shine looks like a good product. I have used the Micro-Mesh kit for restoring plastics. Its the aviation gold standard product for polishing plastic. We restored a guys  aircraft windscreen with it once. I have polished all sorts of plastics with the kit I bought and it never seems to lose its effectiveness. Best thing I ever bought for $25. I use the K70 kit on clear plastics and finish it off with Finesse-it II ultra fine polish on a lambs wool buffer. I have excellent results that way. Ck out the Micro-Mesh kits here:
http://www.sisweb.com/micromesh/acrylic_plastic_hand_kits.htm
72' Cuda restomod
70 Mustang Mach 1
01' Honda 1100 Shadow Sabre
96' Seadoo Challenger
Offline BIGSHCLUNK
Re: Lens polishing
« Reply #7 on: November 26, 2005 - 09:13:26 AM »
I have used NOVUS you can get it at certain speed shops of small airports believe it or not. I waas told it was originally designed to take the scratches out  of small aircraft wind shields. But I got mine on EBAY. it comes i 3 stages and works pretty well. having a bffing wheel on a cordless drill helps to. Dont use a buffer to many R'S. They also have a website you can order from but ebaywas cheaper
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
Offline miketyler
    • www.miketyler.net
Re: Lens polishing
« Reply #8 on: November 26, 2005 - 11:14:20 AM »
I use a buffer all the time but am VERY careful about bonnet speed and am constantly putting my hand on the work to monitor temperature.
Also, fair to mention the applications for these products. The abrasive kits shouldnt be used to bring back clarity on large surfaces. They are designed more for deeper scratches and spot repairs and do well to that end.
Larger surfaces with MINOR scratching or fine hazing can be treated with Novus or other ultra fine compound and then finished with an anti-static cream or something like Meguires plastic polish. Meguires has no abrasive content; it is more like a lubricant fine liquid filler. It is the final step in any of the plastic restoration processes I use.
72' Cuda restomod
70 Mustang Mach 1
Offline miketyler
    • www.miketyler.net
Re: Lens polishing
« Reply #9 on: December 05, 2005 - 05:26:27 AM »
another excellent product is one I just used this weekend for my rallye guage lens assembly. I got GREAT results with it. It is a simple polish that can be applied by hand. It is designed to restore clarity in acrylic plastics and is called Novus. Comes in 3 flavors and is used widely in the hobby industry. I would use this over any abrasive kit if I just had mild suface scratches. Is a helluva lot quicker too.
72' Cuda restomod
70 Mustang Mach 1
Offline BIGSHCLUNK
Re: Lens polishing
« Reply #10 on: December 05, 2005 - 07:26:48 PM »
the stuff miketyler shows in the pic is the stuff I used!check it out! :jumping:
                                             [o o o o]
                                                  OO
                                                  OO
                                              [o o o o]
