Author Topic: Bearings?  (Read 1060 times)
dodgetkboy78
Bearings?
« on: November 07, 2005 - 12:34:49 AM »
What were OEM bearings from the late 60's/early 70's made out of?
Re: Bearings?
« Reply #1 on: November 07, 2005 - 11:07:31 AM »
which bearing ?
, engine bearings are steel backed & babbit lined , most good replacement bearings are tri metal , steel lined , copper in the middle & babbit lined
dodgetkboy78
Re: Bearings?
« Reply #2 on: November 08, 2005 - 02:20:21 AM »
Mains and Rods......................
Seems like the old bearings last longer than the new ones..........................................(sigh)
Re: Bearings?
« Reply #3 on: November 08, 2005 - 10:33:12 AM »
not if the machining was done correctly
dodgetkboy78
Re: Bearings?
« Reply #4 on: November 08, 2005 - 11:12:11 PM »
I just dont get it. I pulled a 318, out of a 2 ton truck, with over 300,000 miles. the bore is good, the crank is good, (steel) and the dang bearings are even good!
Unless it was rebuilt with a OEM gasket kit, and not bored or turned, the dang thing has the 315,*** miles the maintenance log said it did. (It did have a wore out double row chain)
Re: Bearings?
« Reply #5 on: November 09, 2005 - 12:31:41 AM »
the bearings should have the date on the back of the shell
dodgetkboy78
Re: Bearings?
« Reply #6 on: November 09, 2005 - 10:23:05 AM »
8-71-07******
Re: Bearings?
« Reply #7 on: November 09, 2005 - 08:38:47 PM »
aug 71
dodgetkboy78
Re: Bearings?
« Reply #8 on: November 10, 2005 - 02:05:09 AM »
holycrap.
