They look like the same thing but you can see one is built cheaper and the Mopar pump is probably the high performance pump. The 40.00 pump should work fine but if you are trying to be correct in the term as it is used in restoring your car I'd go with the Mopar pump, if you are tight on cash, the 40 dollar one shouldn't leave you hitch hicking out on the road somewhere.
