Author Topic: Interior door panels  (Read 2687 times)
Offline firemedic
  • I'm a llama!
« on: November 11, 2002 - 03:56:53 PM »
I have a 73 cuda that i'm restoring, the interior panels in the car have been painted over by a different color than the original color. I was wondering if anyone knew a good way to remove the paint without damaging the plastic, or a way to repaint them.
thanks
Offline 70vert
Re:Interior door panels
« Reply #1 on: November 11, 2002 - 04:19:11 PM »
A company called SEM makes sprayable vinyl dye. You can get it at any automotive paint supplier. It sprays on with a paint gun. Treat your panels with a plastic or vinyl prep before you spray.
We don' need no stinking bowties!!!
Offline wmiller
« Reply #2 on: November 11, 2002 - 11:16:15 PM »
 ;D ;D Try using some lacquer thinner on some clean cloths to remove residual paint. Use outside, wear rubber gloves, good ventilation. Use only enough thinner to dampen the cloth--NOT SOAKING WET. This will allow you to remove the paint and won't damage the plastic. Go slow and check your progress. I have used this process on seat backs that were painted and it worked great. Good luck. ;D ;D
Offline weatherwiener
  • Newbie
  • 73 'Cuda
« Reply #3 on: April 17, 2003 - 10:51:10 AM »
Ive got a '73 Cuda also.  Did you happen to track down any interior paint codes?  Ive got the 2 tone blue interior and want to make sure that I do it right!!
Offline andergen
  • Newbie
  • I'm a llama!
« Reply #4 on: September 10, 2003 - 03:11:36 PM »
I've got a set of interior panels, three black and one brown, that I want to change to blue.  The salesman said I needed to know what kind of plastic the panels are made of in order to get the correct SEM products to prep them for spraying the dye.  Are they made of ABS plastic or some other type?
« Reply #5 on: September 10, 2003 - 05:42:49 PM »
 ;) My best guess is they have to be ABS. The only real test would be to shave a little bit off, and see if it smokes when heated with a soldering iron or something hot. I would REALLY be surprised if they weren't ABS.
