Author Topic: timing and carb setiings!  (Read 722 times)
Offline Mr. 6pak2go
  • Restore it dont crush it!
« on: November 08, 2005 - 07:28:30 PM »
A friend of mine has a 400 big block in a satalite and he was wanting to know what size carb to put on it! i told him a 700-725 but what do you think??  also where sould he set the timeing on a 400?? I didnt know so i figured id ask!! thanks Kevin!
My family, My cars, My guns three things il fight for!!
Re: timing and carb setiings!
« Reply #1 on: November 09, 2005 - 12:25:19 AM »
I would use a 750 minimum , I prefer the Holley / Demon style carbs
 Mark the timing damper 2 /3/8" clockwise from the TDC mark & set the timing at 36* at 3000 rpm , i would put an allen wrench into the vacuum advance on the dist & turn the screw counterclockwise 8-10 turns first , if it pings at 36* turn the screw a couple turns clockwise & reset the timing to 36* at 3000 rpm
Offline Mr. 6pak2go
« Reply #2 on: November 09, 2005 - 03:49:51 PM »
ok thanks chryco il tell him!
