Camshaft Recommendations! 408 Stroker
Author Topic: Camshaft Recommendations! 408 Stroker  (Read 15465 times)
Offline Mr. 6pak2go
  • Restore it dont crush it!
Re: Camshaft Recommendations! 408 Stroker
« Reply #15 on: November 10, 2005 - 04:10:01 PM »
As ironic and un-loyal as this might sound....I think all of the Mopar performance stuff is overpriced junk. Take the MP distributor for example. Its the same as a stock over the counter one from Autozone (better off with MSD though)! The cam grinds arent that fantastic either. Personally, if I'm gonna buy a cam, I go to the people who specialize in making cams, their reputation depends mostly on how well their cams do, so they put alot of effort in making them the best.
I have went with MP parts on chassis stuff, only because they were the only ones who made what I was needing and those parts have been ok. Not really impressed with the Leaf springs I bought either though. The way I see it, MP is trying to take advantage of the mopar people who think just cause it says Mopar on it , it must be the best.
  i disagree mp purple cam shaft is one of the best durable cams made!!
My family, My cars, My guns three things il fight for!!
« Reply #16 on: November 10, 2005 - 10:58:16 PM »
Comp has the investment cast stainless rockers if you want roller tips, I use a lot of the Crane iron rockers for street use , they are very tough & work well but no roller tip
 the summit link didn`t list a mopar part
dodgetkboy78
« Reply #17 on: November 11, 2005 - 01:03:20 AM »
I think there are better, but, wouldnt knock them either.
Offline dst
  • Negated Identity Construct
« Reply #18 on: November 11, 2005 - 10:02:04 AM »
Looks like you can’t link via the URL in the address bar. Here is the part number:  CRN-69770-16 Crane Steel and Ductile Iron Shaft Mount Rocker Arms. Would I just reuse my stock shafts with these?
I also found these: CRN-69790-1 Crane Gold Race Extruded Shaft Mount Rocker Arm Kits.  Aluminum, full roller, and come with shafts. For 120$ more.
There are those who have fallen and those who are going to fall.
Offline ACE_5150
« Reply #19 on: November 18, 2005 - 11:26:19 AM »
Actually, I have had alot of luck and good service from Hughes engines. They specialize in MOPAR, and know what theyre doing. Not exactly cheap though. I got a roller rocket set for 300 dollars and love em.
"An Adrenal Gland is a Terrible thing to waste!"
"Bad Cop, No Donut!"
« Reply #20 on: November 18, 2005 - 09:04:32 PM »
I use the ductile rockers for street use , if you are using double valve spring I would use the thicker Crane rocker shafts to stop them deflecting  under load
Offline dst
« Reply #21 on: November 18, 2005 - 11:53:15 PM »
What do you guys think of these rockers?    Competition Cams Pro Magnum Shaft Mount Roller Rocker Arms
http://www.powerandperformancenews.com/store/merchant.mvc?Screen=PROD&Store_Code=CC&Product_Code=1322-16&Category_Code=pmRCKR
http://store.summitracing.com/default.asp?target=egnsearch.asp&N=400114+309466&autoview=sku
These are what the machine shop recommended.  With these, I can use ball-to-ball pushrods and not have to buy custom ones. The machine shop said they would loan me a few pushrods to find what fits.
Thanks
-dust
Btw: the 'machine shop' is SpeedOMotive.
« Reply #22 on: November 19, 2005 - 10:35:20 PM »
those are awesome , premium quality rockers
