4spd conversion for Challenger???
Author Topic: 4spd conversion for Challenger???  (Read 1688 times)
Offline bennydodge
« on: November 12, 2005 - 03:19:29 PM »
Has anybody converted from a 727 to an A833? I know Keisler makes the TKO 5spd conversion and I really like it but it's very pricey(read: can't afford it). I know Passon Performance sells rebuilt A833's but I'll need linkage,pedals,driveshaft,etc. Is this even feasible? My 727 works great but I want a manual trans in the worst way. Tell me whata' think guys.
1973 Dodge Rallye Challenger 340(416 stroker), 727 ,3.23 SG, 76,xxxmi.
2010 Ram 3500 CC Dually 4x4, Cummins, loaded
2015 Challenger R/T classic B5 5.7 8spd
Offline bennydodge
Re: 4spd conversion for Challenger???
« Reply #1 on: November 12, 2005 - 03:22:51 PM »
I just realized I posted in the wrong forum. Sorry 'bout that.
Offline Plum6Pak
  • Plum6Pak
« Reply #2 on: November 12, 2005 - 04:23:43 PM »
Hey Benny, here's a neat and exspensive item as well. It says it can be used on the automatics or the 4 speeds. Just giving you some more options. I'd love to have one, maybe sometime when I can swing it.
http://www.cuda-challenger.com/cc/index.php?topic=14538.msg147393#msg147393
« Reply #3 on: November 13, 2005 - 01:44:44 AM »
I have converted a Number of cars to 4 spd , not that hard to do the cheap trans is the OD 833 from a truck , it is virtually a bolt in & not too tough to find
Offline Carlwalski
« Reply #4 on: November 13, 2005 - 02:01:12 AM »
If you want it I say go for it!
I'll never drive a manual Mopar unless it was a small block, love my Torqueflight-727 cars, shows on the strip to how good they are.
What is it going into? Engine hp??? Street/STrip? Cruiser?
Cheers,
NZ
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Offline bennydodge
« Reply #5 on: November 15, 2005 - 04:29:44 PM »
Cheers,
NZ
Cheers to you Down Under NZ. The car in question is a 72,000 mi. 1973 Rallye Challenger 340. I took that numbers matching engine and built it into a 416 stroker w/11.5 to 1 comp, Eagle H-beam rods, E-heads, Holley 750HP, Air-Gap intake, MP 474" cam, TTI headers, 3.23 SG, 727, 9 1/2" PTC converter. This is my nice weather car but does see track duty once or twice a year. As far as engine HP, I'd say it's between 425 and 450 horse. It's best run altitude corrected(Denver, CO) is  a 12.7. Of course I'm not done with this engine at all and am hoping to be much faster next year. I'll be posting pics very soon.
Offline Carlwalski
« Reply #6 on: November 15, 2005 - 06:54:21 PM »
Sounds like you know what your doing! Glad to hear you pulled the numbers engine. :-)
So why are you wanting to change to a manual? Just the fun factor or.....??
If you have the Kiesler money option you should also consider a Gear Vendors unit: http://www.gearvendors.com/hrdodge3s.html
Cheers,
Carl
