Author Topic: wheels for disc conversion  (Read 871 times)
Offline goldfish68
« on: November 16, 2005 - 08:01:11 AM »
Well it's been a while.
 After the run around and all the wrong hardware from SSBC I have disc brakes on the front of my fine 68 Barracuda convert.
Now I need some wheels at least 14x7. And what is the proper backspacing and whats BS mean to me? I'm having troubles finding anything but the outlaw 2 rims from American Racing.  Any advice on other products and tire size that'll work with out any more darn conversions??  I'moona need front and rear.
Here's The AR Outlaw 2
http://americanracing.com/wheels/details.asp?wheelid=8&name=Outlaw%20II&style=62&desc=1-piece%20alloy,%20clear%20coated&section=A
Thanks
Offline goldfish68
Re: wheels for disc conversion
« Reply #1 on: November 17, 2005 - 06:44:24 AM »
nevermind then.  Thanks for all your help!
Offline HemiDog
  • Do not Assume!
    • Hemi Dog
« Reply #2 on: November 17, 2005 - 09:40:48 AM »
There aren't too many people who make aftermarket wheels for mopars that aren't a classic design.
To get a newer design you will more than likely have to go with a custom wheel or should have changed your hubs and axles to a different bolt pattern.  Companies like Budnik, Fiske, and Bonspeed are a few places that do custom wheels.  You usually can find info on their sites that will explain what measurements you need to take to get a proper fit.  With aftermarket disks, one over looked measurement is the hub diameter.  Most aftermarket front hubs are larger than stock and won't allow classic steel wheels to even slide on.
I am not familiar with A-bodies, so I couldn't say what a good backspacing measurement would be for the front.  4in is usually good on E-bodies.  I would suggest going to a 15-inch wheel though.  The selection for tires is much greater and the likely hood of any clearance issues with the calipers will be minimized.
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #3 on: November 17, 2005 - 01:19:12 PM »
What bolt pattern do you have 4" or 4 1/2"?There aren`t too many chioces for the 4" pattern which is why most people swap to the 4 1/2".
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
