Author Topic: 1970 cuda engine ?  (Read 833 times)
Offline focal 7
1970 cuda engine ?
« on: November 16, 2005 - 11:23:59 AM »
I asked a similiar question last week, but this is a different car. I found a 1970 cuda this time with a 318 installed (last week it was a 6 cylinder) will my 440 install in this car or do I need a different K member? Thanks for the expertise!!!
Offline pink panther
Re: 1970 cuda engine ?
« Reply #1 on: November 16, 2005 - 11:28:59 AM »
that is the great thing about Mopars, any of their engines will go into any of their cars without serious modifications..  I believe the K-member needs changed (someone can help me out with that) does it have a 8 3/4  rear end now? if not you might want to change that as well since you are going from a 318 to a 440.
cudahob
« Reply #2 on: November 16, 2005 - 11:44:22 AM »
It will fit. What is the vin?
« Reply #3 on: November 17, 2005 - 02:04:03 AM »
all V8 engines except the hemi use the same K frame so no the K does not need to be changed
