4 speed linkage adjustment
Author Topic: 4 speed linkage adjustment  (Read 3469 times)
Offline pink panther
« on: November 16, 2005 - 12:03:29 PM »
My wife has a problem while driving our Chally,  sometimes when she is trying to shift out of reverse the shifter gets stuck and it is like it isn't in any gear.  This only seems to happen when reverse is used.  Will adjusting the linkage correct this problem?
Re: 4 speed linkage adjustment
« Reply #1 on: November 17, 2005 - 02:02:30 AM »
possibly , there is a hole in the shifter body for a pin to slide into that centers all the shift levers then the rods can be adjusted correctly
« Reply #2 on: November 17, 2005 - 07:39:24 AM »
thanks chryco, that is what I have been told, just unsure if it will correct it or not.
Offline Pistol Gripper
« Reply #3 on: November 17, 2005 - 07:58:25 AM »
From Hurst's site:
Q) What is the proper way to adjust my Hurst four speed shifter?
A) There is a 1/4 inch hole at the bottom of the Hurst mechanism that runs through all three levers. This is called the neutral alignment hole. To ensure proper adjustment, run the shifter from first into second and then back to neutral. Insert the neutral alignment pin (or a 1/4 inch drill bit) into the neutral alignment hole. If the 1-2 lever interferes with the smooth insertion of the alignment pin, remove the 1-2 linkage rod from the shifter and thread the adjuster button either in or out to eliminate the interference. Repeat this procedure with the 3-4 lever and reverse. To adjust the stop bolts, back the bolts out of the shifter frame until only a few threads remain. Push the stick firmly into third gear and hold. Screw in the stop bolt until contact is made. Release the stick and back the stop bolt out one turn and tighten the jamnut. Push the stick into fourth gear and repeat the procedure.
or
Q) My shifter jams or hangs up in gear. What is the problem?
A) First, check to see if the linkage rods are encountering any interference. With the engine off and the parking brake engaged, have a friend operate the shifter and observe the linkage rods to see that the rods operate freely. Second, check to see if the transmission arms have become elongated (wallowed out). This may cause incomplete travel. Be sure that the linkage rods are parallel to the shifter lever's travel. If they are "crooked" it may cause binding. Finally, the mechanism may be in need of a rebuild. Although made for years of outstanding performance, the shifter may require a rebuild after several years of use or severe duty. See the rebuild information below should you require this service. All Hurst shifters (with the exception of "Indy" shifters) carry a limited lifetime warranty for the original owner of the shifter. Save your receipt!
This is a Chebbie article, but the idea is the same.
http://chevyhiperformance.com/howto/97440/
The part I think applies to you is:
The shifter must rest in the Neutral position during this adjustment. Hurst supplies a 0.250-inch-thick plastic pin to hold the shifter in Neutral. If you don’t have one of these tools, try a 1/4-inch drill bit or make your own 1/4-inch steel rod (arrow). With the shifter in Neutral and the shift-rod ends adjusted, the shift-rod ends can be threaded until they slide easily into the shifter. It is best to start with the Reverse rod and work outward. Be sure to work carefully as this will determine how well your shifter works.
Hope this cures some of your hang-ups.
P.G.
O ne
B ig
A $$
M istake
A merica
« Reply #4 on: November 17, 2005 - 10:20:52 AM »
Thanks alot Pistol, I will definately give it a shot.  Going to start doing some of these things since it is now officialy time to start on the "winter projects"  I will let you know how this works out.
Offline chevyconvert
  • HvacMan
  • Member since November 04, 2005
« Reply #5 on: November 28, 2005 - 10:25:21 PM »
good info for the old file cabinet .  :cheers:    Thanks pistol
Eric
'70 Hemi Orange RT/SE 440 Six Pack Pistol-Grip 4 speed
Bay Area California
