Did all R/T's and Cudas come with Rallye dash?
Author Topic: Did all R/T's and Cudas come with Rallye dash?  (Read 5893 times)
Offline cudacharlie
  • 70 Cuda convert, 70 Charger R/T
« on: November 23, 2005 - 05:34:48 PM »
Wondering....  was the non-rallye (black plastic) dash correct on any Cudas or R/T Challengers, or was the woodgrain rallye dash mandatory on performance models?  What criteria determined availability of non-rallye dashes?  I know you know......
70 Cuda convert
70 Charger R/T
06 Magnum SRT8
Re: Did all R/T's and Cudas come with Rallye dash?
« Reply #1 on: November 23, 2005 - 06:07:11 PM »
As far as I know, the Rally dash was optional on any model. So the non-Rally would fit on any E-Body.
Offline Carlwalski
« Reply #2 on: November 23, 2005 - 06:33:20 PM »
I thought the rallye dash was standard on all R/T models? I just can't think of any R/T's that I've seen with the standard cluster.
1970 Dodge Challenger R/T
White, License Plate, 0A-5599
Alaskan_TA
« Reply #3 on: November 23, 2005 - 06:40:26 PM »
I am not sure about later years, but for 1970 The Rallye Cluster was standard on Challenger R/Ts and optional on all other Challenger models including the T/As.
Barry
« Reply #4 on: November 24, 2005 - 12:01:11 AM »
I believe 71 is the same , I have never seen a 71 R/T with a std dash same goes for later Cudas & Ralley Chals , all I have seen is ralley dashes in them , the T/A & AAR definatly did not come with ralley dashes unless it was added , ther are a lot with std dash clusters
Offline RUSTY Cuda
  • One big step foward!
« Reply #5 on: November 24, 2005 - 07:51:35 AM »
On the later cuda's I think it was still an option, was asked if I wanted it on the order sheet, 99 % sure but it was 31 years ago! The 74 "texas" cuda, is a BS23L & it has a standard dash.
kudakidd
« Reply #6 on: November 28, 2005 - 12:26:09 PM »
The guy who ordered my Kuda didn't believe in frills!
Offline N96cuda
    • Kirks Cars
« Reply #7 on: December 03, 2005 - 11:56:04 PM »
It was a $90.30 option on 70 Cudas'. My 70 has it, my 71 does not. Considering the entire shaker setup was exactly $7.00 higher, it does seem pretty expensive.
70 Cuda 440-6 Shaker, Auto, Vitamin C, stripe delete, black int. & vinyl top, luggage rack, Magnums, build sheet
71 Cuda conv. 383 4-speed, Rallye red, black top, int. and billboards, 2 complete build sheets
09 B5 blue Challenger SRT-8
www.93cobra.itgo.com
Offline BarryBum
  • 72 Cuda 340/Pistol Grip 4 Speed
    • Missionary Wesleyan Car Show
« Reply #8 on: December 07, 2005 - 06:32:17 PM »
My 72 340 Cuda does not have a rallye dash. My Cuda was ordered with nothing!!!!!  The only thing she has is power steering and power brakes............other than this thing sticking up out of the floor :burnout:  A NO frills running machine.
Offline hemi71
« Reply #9 on: December 07, 2005 - 07:12:11 PM »
Rallye dash was standard on Challenger R/T's only. On any year Cuda's it was an extra cost option. But any barracuda or Challenger could be equipped with a rallye dash if the option was checked off on the order sheet.
The below 70 Cuda 440-6 4speed car was not rallye dash equipped
« Reply #10 on: December 09, 2005 - 12:18:18 AM »
makes sense , but I though 440+6 Cuda came with Shaker hoods , was that car a delete ?
Offline hemi71
« Reply #11 on: December 09, 2005 - 12:22:16 PM »
Only hemi cars were standard shaker hood equipped...even 440-6's were standard with a rallye hood with the shaker being an extra cost option.
Here's another good one....440-4 bbl cars with 3.23 gears were standard 22 inch radiators! Only when a optional gear ratio was ordered (3.55 and up) or A/C equipped was a 26 inch radiator required. My 70 Challenger R/T ragtop (440-4 auto with3.23 SG) was a 22 inch radiator car from the factory, and when i talked with the original owner, he told me that car ran hot from day 1 in the summertime.
« Last Edit: December 09, 2005 - 04:57:21 PM by hemi71 »
Offline cudacharlie
« Reply #12 on: December 09, 2005 - 10:05:27 PM »
Very in-ter-es-ting....
It makes sense that Challenger RT's all came with the more upscale dash, but that it was an extra-cost option on the Cuda, since even though the Cuda was a performance model, it was positioned as more of a down-and-dirty street car than the more luxurious Challenger, the "executive's hot rod".....
70 Cuda convert
70 Charger R/T
06 Magnum SRT8
Offline alohaautomotive
« Reply #13 on: December 13, 2005 - 12:48:10 PM »
Our 70 Hemicuda has standard gauges....hehe
daves70
« Reply #14 on: December 19, 2005 - 05:52:47 PM »
I've never seen a 70 challenger r/t without rallye gauges.
