It's an easy upgrade to make, basically you use the factory wiring as the trigger wire, energize the relay off the alternator directly, then run the the wires out to new headlight pigtails and plug the lights into those. Takes the major load off the factory wiring and really brightens up those night cruises. There are tons of how-to's on the 'net if you need full details.
