1973 Dodge challenger swap auto to manual???
Author Topic: 1973 Dodge challenger swap auto to manual???  (Read 1735 times)
Offline 383challenger
  • Newbie
« on: November 23, 2005 - 07:07:24 PM »
Hello, I plan on changing my trans in my 1973 challenger from a auto to a stick the car has a 383 with a 727 in it now.  I plan on buying a 1973 dodge charger with a 340 and a 4 speed manual trans.  I want to put the stick in my challenger.  My question is will the clutch linkage and pedals from the charger work in my challenger.  I know I will need a different bell housing for the trans to bolt up to the big block and I will need the 4 speed hump in the floor.  Just want to know if this will work.  Thanks and I will be waiting for your replys.
Re: 1973 Dodge challenger swap auto to manual???
« Reply #1 on: November 24, 2005 - 12:12:23 AM »
Welcome
I haven`t actually done this swap but B & E bodys are very similar but the rest "should" work , Dodge didn`t make 2 different parts very often & generally used the same parts in B & E bodys , I have used earlier 71 pedals etc from B bodys in E bodys
Offline torredcuda
  • Epping NH joined 11/23/03
« Reply #2 on: November 25, 2005 - 06:07:57 PM »
The pedals should work,not sure about the linkage.You will also need a frame bracket for the linkage which is avialable as a repro.
Jeff
72 Barracuda 340/4spd  Torred
04 Ram 2500 5.7 Hemi
